1998 tahoe LS swap
SunlitComet
OBS Jedi-Do Good
unknown at this time.
would suggest changing that intake to on based on the plastic high density polyethylene material. it isolates the engine bay heat form the intake air by a huge margin.
2drhoeon4s
updates.....
and a few pics of earlier stuff...
Got my Gauges installed for tach, oil press, and coolant temp.
Coolant and oil sensors on my adapters..
special socket for removing the oem oil sensor..
I had a fuel leak on my Earl fitting out of that little hole...... I thought. So I bought new fittings..
Turns out i forgot to tighten one of them.... oh well now I have spares.
I borrowed a neighbors welder so I can do my exhaust.. Pipes and bends should be here tomorrow from summit.
Dual 3" with E cutouts back to a dual inlet single outlet 50 series muffler..
Im thinking my shake/ misfire problem was a bad plug....
Nice and wet..
Also got my Headlights and fogs and tails hooked back up and tested..
---------- Post added at 10:36 PM ---------- Previous post was at 10:35 PM ----------
got most of my exhaust mocked up.. now I have to weld it all..
nobsobs98
This is just beautiful, everythings done so clean and right. I think i need to go grab some tissues... and not because im crying.:Rock on:
2drhoeon4s
hahaha thanks!!! Im digging it so far just a few bugs to work out and she should be on the road!!
arctic388
cool swap.
if i may ask what happened to the original motor? is it for sale?
YAMBAG
westport MA
Awesome thread. Hows has the truck been running for you?
Id like to do this same swap in my 98 2 door. I think my biggest area of confusion will be the wiring. What did you do and use for the wiring change over?
Do you have a lost of parts with part numbers for all fuel fittings and sensor adapters needed for the swap?
X-ray Nerd
