vLED fogs, reverse lights and license plate lights
twhitechurch
There are some led headlight replacements, some are reaching 2000lm per bulb which is similar to halogen.
Sent from my SM-N900V using Tapatalk
twhitechurch
Vleds they have a good assortment. Remember that truck has h11 headlights
sevTahoe
But that doesn't look like a simple bulb swap out (i.e., factory fittings--am I mistaken?), and it actually says not recommended for projector headlamps.
http://www.vleds.com/headlights/led/h11-h8-h9/h11-5k-mtg2.html
---------- Post added at 11:24 PM ---------- Previous post was at 11:15 PM ----------
Here we go! Update once the sun sets :)
---------- Post added at 12:07 AM ---------- Previous post was Yesterday at 11:24 PM ----------
Wow, high quality is right! These are really beautiful in person...
(pencil for scale)
sevTahoe
Before (fog color comparison)
After (vLEDs)
Plate (stock on left)
Really pleased. Thanks so much to Steve1081 for the post!
Last Chance
Thanks for the info! Just received mine and installed them. Looks much better!
S
Steve1081
Glad I could help!
hosseface
Received the following from vLEDs today and installed:
5k white 10 LED PS24W - fogs
5k white 15 LED 921 - reverse lamps
5k white 4 LED flank W5W - license plate bulbs
I had previously installed silver star incandescent bulbs in the reverse lights and Philips extreme vision 4k LEDs in the license plate. But wasn't really happy with the improvement. So when I ordered the LED fogs I got 5K vLEDs bulbs for these too.
Plate bulbs:
Stock left and Philips led right
Philips LEDs (not much better)
Philips LED right and vLED left
vLEDs (way brighter)
vLEDs lighting up the ground
Reverse lamps:
Stock right and silver star left
vLED left and silver star right
vLED reverse lights (still Philips 4k led plate bulbs)
vLEDs for both reverse and plate bulbs
Ground shot of overall light output in reverse
vLED bulb in reverse light housing
Fogs:
Stock left and vLED right with 4300k TRS HIDs on
Both vLED fogs with headlights off. 5K is a good match to DRLs
vLED bulb in fog housing
Also installed 4K osram highbeam bulbs from TRS. They match the LED fogs and HIDs much better than stock. Kinda hard to capture high beams in a picture but here is a shot at it
Overall i am very happy with the results. The vLEDs bulbs are definitely much brighter than the Philips and a better value. High quality and super bright!
Tell me more about the 4K Osram high beams from TRS. Maybe a link to what you used?
Thanks!
mikemal565
VLEDs are the best.... This set up is fantastic.... The backup bulbs were on back order, but now have come in Stock...
I did a little video of the fogs from the front in my garage.. Part shade, part sun
2015 Yukon Denali XL with 5k LED (VLEDs.com)* Fog…: http://youtu.be/aVJ77CSLMTo
Can someone please explain how to get the fogs in and tailights removed to install the reverse lights? I'm stumped.
---------- Post added at 10:04 PM ---------- Previous post was at 08:55 PM ----------
Ok, got reverse lights installed and one high beam but have no clue how to get the fogs and the passenger side high beam done. Looks like I need to remove the air box to install the other high beam, but my hands can't seem to fit in the space to change the fogs.
fszatko
WI
I did my fog lights in 10 minutes last night. I am 270# and 6'2" with big hands but had no problem. Flashlight in my mouth. Squeezed under front bumper/fascia on my back. Squeeze two white tab (top & bottom) to remove the light/wire unit from the housing. Then able to pull the light/wire out for better visualization. Then remove black wire harness from back of light.
On re-install, I found it easier to install the lamp into the housing first. One side of light has single fin/ridge. Other side of light has double fin/ridge. Make sure to line them up properly in the housing. Then, align black wire housing and press into light.
I installed the license plate, reverse and fog lights last night.
I noticed the same problem with the passenger high-beam. I haven't tried to tackle that yet, but looks like some dismantling required.
S
Steve1081
You just remove the cable to the MAF loosen the hose clamp and pull up on the air box. It is held in by rubber grommets. It only takes 5 minutes to remove.
El Train
Thank you for this thread!
I bought them from VLEDS.com and they took about 5 mintues to install. I just did as others have said. Slide under the middle of the front, right under the emblem where the lower air dam is the highest. You can look over to each side and see the wire sticking out of the fog lamp housiing. There was one tab on top of the black wire harness, just push that down and it came right off. Then you can see the white plastic backing of the bulb sticking out, there was a tab on the top and bottom, you squeeze them and they come right out. I put the new bulbs in squeezing the tabs and they popped in once in place, then did the wires. The whole thing took five minutes, ten at most because I stopped to take the picture. They look great, very satisfied!
The license plate bulbs are on backorder but look forward to them too. Now i need to look into installing some HIDs.
The old halogen bulb is on the drivers side.
Item Sku Qty Merchandise
5K WHITE 10 LED DRL/FOG LIGHT BULBS 5201 5202 9009 2504 PS24W PSX24W | 1 PAIR 5202_10_XB_W_5K 1 $60.00
5K WHITE 4 LED HIGH POWER FLANK BULBS 194 168 158 160LM | 1 PAIR 194_4_HPF_W_5K 1 $18.00
WJK1
Thanks for the post and pictures. Was surprised this wasn't done from factory. This is a must do mod!
---------- Post added at 12:52 AM ---------- Previous post was at 12:12 AM ----------
Just checked out the site. Has anyone gone up to the 6k bulb? 6k License plate bulbs are not on back order at the moment.
S
Steve1081
6k will have a more blue look. Factory HID bulbs are typically 4300K. If you google you can see plenty of pictures of what the 6k LEDs look like. If you like the look then go for it.
PavementPounder
Cincinnati
Is there any difference from the 2015 to 2015i Yukons? I'm about to order but want to make sure I get all the right bulbs (fogs, plate, reverse)
Buford bubba
