stock distributor or msd street fire distributor
MACJR90
so I bought a MSD Ignition 5592 street fire distributor I figure why not since old one has a broken tab where the screw goes for the cap so my question is will my truck have any problems running with this distributor?
MACJR90
MACJR90
I run the MSD in mine as well and never had problem with it.
Thanks for responding guys I had a guy at advance auto tell me my truck was gonna run like sh## with the msd distributor for some reason
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Mine failed after nine months but was a screw up during the manufacturing and lack of literature on the issue. second one is corrected this time. otherwise absolutely no issues with bad gears or bushing or firing issues.
TigerEyz3
Slow and Steady
TN
I'm running the MSD distributor as well... Only thing to be aware of (when replacing any distributor) is to make sure you not only line up the pointer with TDC of the #1 cylinder, but it helps to check/set the Camshaft advance/retard (+/-2*). Otherwise, you'll potentially get the "run like crap" situation.
vdesolution
