Need help badly
Yukonman11
Hey guys I'm new to te forum and I need some help badly,
I was replacing the speakers in my 1994 yukon gt and the wouldn't fit cause there was a thick ball of tape wrapped around the wires and I wanted to retape all the wires and make them neat so I took my door panel off and unplugged the window switches, lock and unlock button and the side mirror switches.. Then i tried to unplug the lock and unlock switch an then I accidentally pulled the wires out the plug but I rewired them the way they were,then when I unwrapped the ugly mess of tape, and I noticed that the wire for the lock and unlock switches was cut on the driver side so I pulled the wires apart and wired them back togeather and retaped it all nice, after all that was done I plugged everything back in and when I turned my truck on my drivers side window wouldn't roll up but my passenger window would, then I unplugged them again and blew out the plugs to get any dust out, then I plugged them back in and when I tried to roll up my windows my windshield wipers came on and my truck started making a beep sound as if my key was in and my door was open, then I tried to see if my heat was working and it just made a buzzing sound, and my Gage's started freaking out, if anyone can help me figure out what's wrong please let me know and thank you so much
Y
Yukonman11
Candy someone post a pic of this plug on the drivers side door panel so I can match it up with mine
Huntin Truck
Minnesota
If you are having all of those electrical issues then you have some crossed wires and/or some short to ground issues. Your best bet is to get a wiring diagram and trace the wires coming thru the door. If there was a big ball of tape with cut and repaired wires then someone has been in there and probably screwed things up.
Y
Yukonman11
Where can I get the diagram
retorq
Kingman AZ
I'm sure Sunlit will be along any moment to post his pirated copy.
Y
Yukonman11
well i went out today and tried to start it and it fired up and the windows work fine and every thing is back to normal i didn't touch anything, but now when i start it it shuts off 30sec after i start it, and then it will stop turning over like when i turn the key it does not do anything but when i wait like 2min it will start then shut back off, could it be out of gas, but i don't think that's it
Candielaine
