XB bulbs
So I called the retrofit source (bulb validation) and it seems the upgraded bulbs (the XB option) +20.00 are the ones we require due to the ground plug on the lower? The standard is on top.
The guy on the phone stated the 14 Sierra's used the XB as well. He said the other bulb would work but the shadow lead (might be wrong wording on my part) would be up top not on bottom.
So, I am just going to send back the unit and get the XB bulbs.
After reading the postings by soulsea (and others), I guess they are a crap shoot. If they are blinding and light is going everywhere, I will not use them. If they have the same containment pattern, I will be ok-I think.
Now, here is the real question for GM techies....Is the 2015 Denali's projector the same specs/part number as the 2015 Yukon (just the low beam projector housing) Or would they do it that way?
Meaning, they have the (same) correct projection assembly for either model, but they put in halogen in one and HID with ballast in the other.
any ideas?
Thanks,
Steve
any ideas?
Thanks,
Steve
