Lift Keys, 2" Spacers, 33s on 20s
LabGeek24
Mempfrica
Looks Great! Bout to add 1.5in Spacers to the rear of mine and change to Bilsteins in the rear
Finely got mine done!!! No more crappy airride problems!!! Moog z71 springs $50, 2" coil spacers and 3" keys $115, TJ 3" rear sway links $50!!!
Before @ 35" on the front 36" on the rear measuring ground to fenders
After @40" in the front 41" on the rear same ground to fender
(please excuse the dirt and finger prints)
I'm still scratching my head on the differences in height??? I love it!!! But it should have 2-3 in the front with 3-4 in the rear??? I guess it was lowered???
criffaaa1
Looks great, can you post link s too where you got your posts for the lift? I want to exact an thing to my 05.
sent from my Crifftastic $3
Here's the part numbers and prices for rockauto and the current discount code good until 3-30-14. These sway links I put on the front. They're stock replacement but mine were shot so changed them out they were bout 3/4" longer then stock. I recommend changing the spring isolators out mine where worn threw.
Rear sway links I used TJ 3" rear lifted sway links are supposed to be the same as we need for the 2" spacers. You will also need 4 1/2" bolts washers and nuts I forget the length but I'll post Monday if I remember
My choice in Rear shocks Bilstein 5100's 3"lift!!!! They have more reach and only bottom out about half an inch less than the 1" lift shocks.. Oh and btw I'll never put another shock on other than these!!!! Before I cranked my keys all the way my ride was better than my factory Denali air ride!!! Only dif now is pot holes or bumps are a bit stiff cause of the UCA STOPS but other than that my wife says it's better and loves the lift minus not have step yet lol
My choice in Front shocks Bilstein 5100's DUHHHH
Keys and Spacers
My posted eBay ads shipped same day!!! My Rockauto order did as well best freaking auto parts distributor ever!!!
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
Dude your ride looks great!! Perfect lift and thanks for doing research on the sway bar end links! I have the TJ rears but will order some fronts. Just for the record if you have a Denali then you already had Z71 springs (Heavy Duty). There is a picture of the difference in this thread. Denalis, Z71 Hoes, and Escalades all had the heavy duty springs. Anyhow your fender #s are correct and pretty good gain! Mine measures between 39.5-40" on the front and 40.5-41" rear with same tire, so I would say yours is within the norm or better.
I pulled the one on the left out. Labeled western chassis??
YukonXL04
The Riverboat
Arlington, TX
Hey everybody, From what I read the z71 springs only add like .5" to height. If thats the case when why swap springs?
2005SnowKon
Fort Collins, CO
What size wheel and tire are you running?
Sent from my SPH-L710 using Tapatalk
chrisreed822
North Richland Hills Tx
I'm a little confused I guess. How did you get a 5 inch lift out of 2" spacers and Z71 springs and 5 inches in the front with just using 3" keys? I put 3" spindles in the front, 2.5" spacers in the back with 5100's all around and I'm sitting at 39.5ish at all four corners. So I wonder if I could change out the springs and add keys to get another 1"-1.5"?
Also, I started at 35.5" front and 37"LR 37 1/4"RR.
I got more than .5" I promise you that!!
275/60/20
20x9 w/ 0 offset
I'm guessing I pulled out a lowering kit???
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
Average lift gain from stock to z71 springs is .25-.5" but it does vary for each car. The benefit to swapping springs is the additional coils handle a higher payload for towing. Another plus to swapping the springs is when the front is cranked the rear has the same rebound feel. The stock rear springs are squishy with cranked keys and the z71 springs feel even with front.
That's a decent gain from a 2wd lift and yes if you add keys and z71 springs you will gain another 1" in the front and .5" in the rear.
Yes I assume you pulled out a lowering spring.
Oh and btw
there's a brake line bracket you have to bend!!! It bolts to the rear dif housing up top!!! There was no slack in it when i got everything bolted up set back on the ground... If you haven't addressed this you might want to check on that so you dont rupture your rear brake lines.
01Konvict
01Konvict
Boats n Hoes
Raleigh/SML
I adjusted mine when I put Russell stainless steel brake lines on it but yes you should bend the bracket down so when the rear suspension is at max travel it doesn't pull the line. Good input!
TheAutumnWind
Keys and Spacers
Excellent, this is useful information.
---------- Post added at 11:03 AM ---------- Previous post was at 11:00 AM ----------
Interesting. I had read that the 'Nali and Esky have short softer springs, since the air ride can compensate for that.
I guess I don't need new springs when I get around to installing my bilsteins.
TheAutumnWind
canadiandux
