Problem with right turn signal
Sikbrah
Originally Santa Cruz, CA now in Los Banos, CA
Sometimes the right turn signal works other times it flashes a few times then doesn't do it again I have to put it back to the middle then do it again and sometimes it works once then I gotta keep going back and forth. Anyone else have any issues? Think it's time for a new signal switch?
Time2Kill
i figured it out the light socket for the towing lights had a bent pin touching another pin and i think it was shorting it out i bent it straight and now the right turn signal works again! PROBLEM SOLVED!!!!
Good catch, that could of been a real hard one to keep chasing down.
PlazaEJ
Good catch x2!
Corroded socket, corroded bulb base, yada, yada, yada. So, many possibilities.
What made you look at the trailer plug?
briannorris
