Find a turbo set up for it. They're making a big come back lately, and they're built much better than the 8o's with a lot of different options. Look into it.
Sent by carrier pigeon
Yes it probably will yield different results but you can do what I did and contact Comp Cams and see what they recommend.
The cam is Comp Cams LSR .607/.614 219/227 112LSA 54-456-11 is the SKU with that I had to run the dual valve springs.
Im not trying to go the fabrication route. Reliability is a factor. With a wife and three kids ride along on long trip everything must go smooth. No one that I know of has a bolt on turbo kit for this truck.
Not entirely true.
http://www.trickperformanceproducts.com
Not entirely true.
I called comp cams and I was shocked at the cam I was recommended. I told him what I needed it for and that I had no power adder
54-456-11 ....... Here is the link. http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1085&sb=2
Seems rather small to me
going from 3.73 to like 4.10 gear you will notice your fuel consumption greatly increases i never recomend gears like a 4.10 unless using the vehicle to tow a heavy trailer or extreme offroad applications or strictly drag racing
my last truck had 4.10 gears and now this tahoe i have has 3.42 gears i totally notice the difference the mileage is alot better plus driving down the highway at 75 my engine isnt tached out like my truck used to do
