07 denali oil leak
Richi5280
oklahoma
Haven't had a chance to quite get under the denali but, at glance I see some oil coming from where the oil filter is but may be from somewhere up higher. Any ideas? Is this common on the NNBS? Will check it out tomorrow so see what I find. Any input will be appreciated
GM Customer Service
Michigan
Richi5280,
Hello! I understand that you are seeking advice from your fellow forum members to resolve the vehicle issue you are experiencing. I might not be able to give you any technical advice but if you find you cannot resolve this vehicle issue yourself, I would be happy to assist. Please let me know if I can further assist you.
Jennifer T.
GM Customer Care
CrashTestDummy
Pearland, Texas
If the oil filter is loose, you'll be spraying oil all over the place and quickly emptying the pan of all oil.
Do you change your own oil, or use one of the jiffy-types of places? It's possible they didn't take much care removing the old filter, and/or some oil splattered when it was changed. Mobil1 has a tendency to stick to surfaces and drip for months.
We just got one of these trucks, so I'm still learning it. I did notice some oil dripping from the sway bar, which is directly below the filter and oil drain plug, so I wrote it off to stuff that hasn't been cleaned after the last oil change so I'm still checking. Hopefully I won't find some problem with our new-to-us Tahoe. It's otherwise in very good shape.
Chev454ss
"Older" engines had a verticle oil filter. The newer ones have a horizontal filter so it's impossible to change the oil filter without making a mess. Crawl under it with some rags and clean it off, then check after you drive it for a bit.
Kcrowe79
