LED Tails
Grimes
I had none of the issues you are describing. Mine were a perfect fit with no additional/noticeable gap either.
Not sure if it means anything, but yours are not smoked. Given its an ebay item, who knows if there is a make difference or not due to that :p
However, like I said, the gap really is not much, nor is it technically a problem. If you don't like it, through some silicone on it, or simply something to back it so you don't see through the edges.
JochenWoern
Sacramento, CA
Jochen you have the spiders?
No, mine are Sonar X3's.
---------- Post added at 03:15 PM ---------- Previous post was at 03:10 PM ----------
Had the SAME LED Lights on my '06, which was charcoal grey and those were SMOKED. Bought off ebay as well (also the set currently installed on my '04 is off ebay) with the same results, no wiring issues and no gaps.
No offense, but are you sure that you installed them propelry? If I remember correctly, you need to kinda shuv them in the opening with an angle and then align them properly prior to tightening the screws.
05YukonXL
South Carolina
I got the 'Sonar' smoked, which i think is just the regular with a coating?
I'm going to work on them this evening before the sun goes down to see if I can close the gap..
For the wiring on passenger side, the harness just was not long enough. I tried a few tricks to 'pull it' but no doing. The drivers side was plenty long.
2003denali26
Campbell River, B.C, Canada
First impressions: they look good installed and are bright. I was concerned the might look 'ricey' - is that the term? Where as the factory lights glowed, these throw some light!
Fit/finish: they don't seem to fit as snuggly as factory tails .. the gaps between body and tails are visibly bigger. Has anyone else noticed this? I will mess with that again later but seems I shouldn't see through the gaps on the side.
Notes on install:
you'll need to keep clips from factory tails and put on your new Sonars.. Not sure why those couldn't be included with new lights but oh well. Next, the passenger side harness is in my Yukon XL is not long enough to accommodate the extra distance required for plugging in the new light (about two inches too short). Driver side was fine. So I'll be doing some splicing to extend connector sockets for turn and brake lights.
Brightness: Photo shows factory tail on driver side, new light on passenger side (not properly wired yet) for side by side comparison of 'running light'. The camera exposed for the street light, so this gives you a better idea of the comparison between the red tail lights.
I also had these taillights, but I would say thats a body work problem, I have seen some bad fits for taillights/headlights/hoods from ebay but not that bad maybe I am wrong tho???
YukonXL04
The Riverboat
Arlington, TX
I'm goin work on them this evening before the sun goes down to see if I can close the gap..
There is a wire clamp under the body near the frame that secures the wire, you can open the clamp and pull a little slack out there. May work for you
JochenWoern
Sacramento, CA
Were you able to get a better fit?
rippinitup
NY.
mine was not long enough as well, i just got some extra wire and spliced them in, took afew minutes. id rather have some slack then having it stressed.
05YukonXL
South Carolina
Finally.... LED SONARS ARE FIT NICE AND SNUG
Okay guys… here's the latest update and conclusions...
Wiring passenger side:
See photos for reference, In the last photo of this post... I'm pointing to where the harness plugs in ( above the exhaust pipe). As you can see there was no additional slack to be found. I bought a new three wire bulb socket from local auto supply store which had about 8 inches of wire, and spliced into harness giving me the additional length I needed. So now all the sockets fit into light fixture nice and snug.
Fitment/gaps:
(See photo 2nd photo) I realized as I tightened the screws holding the light in place it created a yaw effect, rotating the light toward the back gate and away from the quarter panel… thus the big gap highlighted in the photo earlier in this post. (Did this on both lights). So, the easy fix was to add a spacer where the light made contact on the body panel the screws go through.
I added spacer on the screw clips (see first photo). I tried a few materials before settling on small pieces of a foam yoga matt. ( Not shown in photos is I just wrapped electrical tape around the foam to keep in place on the plastic.) I ended up using two pieces of foam on top 'clip' and one on the bottom clip.
Simply set light into opening, lined up with guides into quarter panel, tightened screws and success! Notice the 'after' photo, there is NO GAP at all, where as before I could stick a pencil in the gap!
Now we are rocking! Thanks to everyone for feedback and ideas. I hope if someone else has these issues they'll find all this helpful and tell us about their experience.
Townsend
Finally getting around to ordering these - quick question though - is everyone buying LED replacements for the white reverse light, or just using the factory light? Hadn't even thought about it until now!
05YukonXL
South Carolina
Well, I bought LED bulbs for my reverse lights and they did not fit as advertised... and I broke the base of one, then busted out the pocket knife to get the other one to fit.. so see the attached photo, driver side has oem incandescent bulb while passenger side has LED. I can say my LED is not as bright as incandescent - but is cooler (Kelvin).
YukonXL04
The Riverboat
Arlington, TX
I bought led bulbs for mine and they are definitely brighter than my halogen bulbs were. I didn't have any problems with fitment of the bulb or the housing.
Townsend
Thanks for the comparison shot :Good or Bad: - I actually prefer the white and will stick with OEM for now. Down the road I could always change it.
criffaaa1
Just installed my smoked spider/sonar tails today that I got from Amazon, and also threw in some 3157 led reverse lights too. I didn't have any fitment issues, but I did run into the short wire(on both sides) problem. All I did to resolve that was firmly pull(not yank)the wires for the plugs and they gave me what I needed and then some.
No hyper flash either, don't know about cruise control yet but I'll update later,
Let me know what you think
sent from my Crifftastic $3
Townsend
These arrived yesterday, and went in last night. EXTREMELY pleased with them, other than the ATS and BRAKE lights that are for some reason now dinging and shining at me on the dash every time I get in the truck...on to the next project...:okay2:
coolchuck
maybe Escalade bound?
DC Suburbs
These look like the lights I recently installed. I am using the regular 3157 bulb for reverse.
CM Burns
Alabama
Are these Spyder's?
I found a pair on Amazon but there isn't a picture of the rear, did yours come with resistors?
---------- Post added at 11:55 AM ---------- Previous post was at 11:52 AM ----------
Are these Spyder's?
I called Spyder, and they said they all come with load resistors, but in every instructional video on their youtube page, you can clearly see there arent resistors present when they are plugging the sockets back up to the new light...
---------- Post added at 12:06 PM ---------- Previous post was at 11:55 AM ----------
Sorry for the effed up quote^ I tried to fix it and it wouldnt submit sucessfully
CrackerJack135
