Project Z06 Brake Upgrade
Blazed
Accepting Donations
Wow that sucks about the spacer because your rims already stick out a lot.
THE YETI
Director of Operations
South FL
Thats what I thought. Thanks though.. agh now I want to go back out real quick and test fit the stocks to make sure. If I can get the stocks to fit the I might have to sell the 26's and go with a different rim.
---------- Post added at 03:13 PM ---------- Previous post was at 03:06 PM ----------
No I had different spindles on my Tahoe. I had Mgh's and these are Beltechs. With Wilwoods I think you have to grind the top of the spindle of the bolt. With these brackets its on the inside of the spindle. . But as you can see in the pic red circle with red arrrow you grind that section for Wilwoods with these brackets you grind the area pointing in green.
I'm going to post this, but it's not going to be favorable. I had to grind the same area on my spindle. Thought that was going to be it. Then once I had the rotor on, the caliper sat off the rotor hat too far and I had to grind more. Just not something I was entirely comfortable with, but I was determined to get it to work. I did get it running but was never happy with it. Didn't feel solid. Which is why I went with wilwood on the Burban.
Seems like you are headed in the same path as I was with the grinding, although I sincerely hope that you can just grind that small amount and everything lines up.
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
Yeah I am hoping as well. I will see once I get the rotors. But tomorrow I am going to work more on getting the bracket to fit right and bolt it up correctly and test my rims
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
Well today will be the day to find out if works or not. I am going to get the bracket bolted up correctly and the caliper put on correctly and test fit my 26's and also my stocks just to know. If they don't fit I think I am going to ditch this idea. I already have some slightly used Wilwoods that I might buy that are black and I will paint Yellow. But thought about it, I rather spend just a little more and get Wilwoods then spend a lot more on getting new rims.
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
I think my stock spindles lined up just fine. I will test and see if the stock rims fit today when bolted up. I just didn't think about it at the time when I had them on yesterday.
Smokymance
Boosted
MI
Did you get the new Z06 rotors or are you going to try it with the stock rotors...wonder if hat height / thickness is different b/w the two to give you different wheel offset.
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
no I didn't get the rotors yet.. But if I can't get the wheel to fit on at all then that will be a issue.
Smokymance
Boosted
MI
Thats when you go down the list and sell parts here :gathering:
I know there is few people that want them!!!
THE YETI
South FL
They should clear stock 20s. Depends on which ones. Mine cleared stock silverado SS 20s.
Something like the Denali where the spokes aren't flat might be an issue.
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
Ok Final test fit on them. I am thinking I am going to go with Wilwoods. I will need a spacer with my 26's to get them to fit. I got them to get on all the studs and pushed back all the way but it touches the caliper. I could go with spacers but I think it will push the wheel out a little to far for my liking as they sit flush now with the fender. The CK's fit perfect with tons of room. Anyway here are the pics
Smokymance
Boosted
MI
If Nathan decides to buy Wilwoods too, you know where to reach, even tho this isnt in the plans!:popcorn:
albac
