NathanJax
Vacation Nathan
Jax, Fl
Added an iPad mini to my dash... <-- click link for info
GalaxyBlackEsky
BlackedoutLT3
MD
Haha, yeah I am working on it piece by piece right now. Got the brackets now buying the yellow Z06 Calipers. Next will be the rotors. But the install wont happen to it gets warmer or in spring.
NathanJax
Vacation Nathan
Jax, Fl
I need to talk to you about it more. I'm leaving on vacation for a week in a little bit. I'll try to respond to your PM or get your # and text you cause I'm real interested in doing it
08grey
Upper control arms, lower ball joints tie rods Ect.... Took all day but worth it.
osidesurfer365
San Diego
Installed new step bars.
Sent from my iPad using Tapatalk HD
strokinpower
Added a quart of oil which really annoys me. I've never had a vehicle that you had to add oil to in between changes.
CHOO CHOO
BackPagePhil
Manheim, Pa
I still add a quart every oil change to mine since I switched to synthetic and go 5k between changes
strokinpower
Its under an aftermarket warranty that probably isn't worth a damn as most aren't. I talked to them about it and they said I needed to start a consumption test I just haven't done it yet.
jebt2921
AR
Attempting a cheap fix to a few worn AC control buttons. Instead of replacing the while unit I found a company called Control Button Renu that makes decals that basically replace the worn oem decal button. Should be interesting.
yOGi420
I'm curious how well the decals look/hold up. They aren't cheap for stickers.
wwiizz
