lowering and removing 4x4 on 95 2 door tahoe
Dvldogyut
I am in the process of getting my tahoe as low as I can get it. I am wondering what I have to do to remove the 4x4. I do not have a use for it at all. It's just extra weight in a vehicle that will be getting close to 2000-3000 extra pounds of stereo equipment intalled.
livingez_123
Sandy, OR
it's not hard at all. You will need to get a 2wd trans or have your output shaft and tail housing switched. Remove the front diff, front axles, replace your hub bearings with 2wd units. longer rear drive line.
D
Dvldogyut
The front hubs were my biggest concern. So the 2wd hubs bolt right up?
njJohn
Aberdeen, MD
I dont think so. 2wd hubs are from 99 and newer. They have bigger brakes. Unless theres a 2wd OBS hub out there. 99 and up lowered spindles can be modified to work.
NORCAL SS
SUV SUSPENSION GURU
torsion bar totally different set up. differetn uppers/lowers and mounts on frame.
T3chn06789
Los Angeles
All i did was take off the transfer case and half of the axles to hold up the wheels.
Been driving it like that with no problems
JeffK
