keyless entry fob reprogam?
HDTECH
I could use a little help if possible lol. I researched the reprogram process and heres what I came up with... with key off hold down unlock button on door. Then while holding unlock turn key on off on off and wait for cycle. Then let off door button and hold lock and unlock on fob for 15seconds until locks cycle. Then key on to exit.
Is that right? If it is what would keep the. System from programing ? I have a new battery and I know the fob works due to this nifty tester at advance.
2000 LT
chauncey0337
MLT, WA
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold
down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the
engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock
the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until
the door locks and unlocks.
This step may take up to 30 seconds.
11. Repeat step 10 NOW for each additional transmitter (including any existing
transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming
mode.
H
HDTECH
so what does it mean that if i do the above and the fobs still dont work? i tried it a few times but it still doesnt work?
chauncey0337
MLT, WA
Did the doors lock and unlock like the instructions say? Is this a new key fob?
H
HDTECH
yes they did react but held the fob buttons down for at least a minute and no change. Did the process a few times. The fob came with the truck, so i dont know if it is original or not.
I found a write up for a key fob with the same rf # or whatever on the fob and the process was specific to that fob style number. it said to jump two ports in the data port to activate transmitter learn. Does that make sense? it just say to use a jumper to jump the two terminals. I feel like im being F'ed with on that one lol. Is anything going to be damaged by doing this?
---------- Post added at 01:40 PM ---------- Previous post was at 01:39 PM ----------
*** Fobs have never worked for me since i bought the rig, owner said they just needed batteries but now idk.
chauncey0337
MLT, WA
I've heard of the jumper method. Is your truck the old body style or new body style? I know in 2000 they released an early model and a late model truck. Mine is the kobut1bt so those directions worked for me. I also saw the jumper method for the other model and believe it is legitimate.
H
HDTECH
ok ill try it again, yes my truck is the new body style. If for some reason these don't link, is there a transmitter in the dash that would need to be checked or where would the next step be?
H
HDTECH
Ok so I tried it again multiple times and still no go. The locks cycled but no response when I held down the fob buttons. I also tried with another fob that came with the truck same rwsult. The jumper wire method. Wont work on mine as there are no wires in the slots the instructions mention.
Any ideas? Thank you.
chauncey0337
MLT, WA
I know you said your fobs came with the truck but are they the correct ones? There are 2 different fobs for these years.
mharders
Just outside of Seattle
Both my fobs stopped working on me at the same time. Replaced batteries and I've tried to reprogram using the method above several times with no luck. In for results!
H
HDTECH
Well I have two diferent ones lol what is the number that I should have on the back of the fob? One is unlock\lock and rear 2x buttons. The other has the red horn button
chauncey0337
MLT, WA
I have the one with the red horn button. I think the other one is for earlier models, but I could be wrong.
H
HDTECH
Ok. I ordered a new fob from the dealer well see what happens iguess worst case 40 bucks wasted.
H
HDTECH
New fob dod the trick! Must have had all the wrong ones lol
blaqout
King Yukon
Indianapolis
I'm having the same issue. A buddy of mine works at a dealership and gave me an extra fob they had laying around. For some reason it will not work, do I have to "initialize" the fob first before trying to set it up for my truck? If so, how is that done?
blaqout
King Yukon
Indianapolis
Got it taken care of, apparently there are two different model number fobs for 2001 Suburban so I just removed the battery clip from the new one and soldered it to the old one, good as new!
vsaravia
