! Dual battery setup I am planning on !
saif najd
Hi every one,
I was searching fo4 the best way to do the dual battery setup the winter is just around the corner and I have to be ready :)
So the plan is to buy this Australian part as you can see (isolator)
What I liked about this is the low voltage and the functions too
More to pictures:
http://i236.photobucket.com/albums/ff231/ez616/DBi140R-6.jpg
And this the plan I liked for installation:
The questions I have are:
1- do I understand that it will charge it self (the second battery )?
2- what kind of harm are we talking about? (If there is any)
3- If I used this setup iam not going to drain the main battery? (By using the sec battery)
4- can I use continues liad on the second battery and running the car at the same time? (Like e-fan)
What are the benefits out of this setup?
Sent from my GT-N7100 using Tapatalk 2
---------- Post added at 12:52 AM ---------- Previous post was at 12:51 AM ----------
Sorry if iam repeating the subject but the oldest not showing the pictures and I am talking about this setup only
---------- Post added at 01:40 AM ---------- Previous post was at 12:52 AM ----------
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It will do what you are expecting however I would lean more to solid state devices when rated for that much amperage. Also typically to to not fry a battery in hot weather from overcharging the voltage outputs of alternators put on this vehicles will decrease as the surrounding temperature goes up. As a result you may not always reach the 13.2 trigger to close the relays where you live. Nothing to worry about much but keep it in consideration. you should be able to use continous load on both. By design tho if the primary battery circuit drops to 12.4vdc it will cut off the auxiliary battery from the primary. You can still drain the two of them separately of course with out one effecting the other. Please keep your e-fan power supply as the main battery. Never hook primary cooling fans to a secondary source unless redundancy provisions are put into place in case of electrical faults in the secondary system.
barney91
mesa,az
Why don't you guys ditch the isolator, as long as you fuse both ends of the positive you are good, i have always ran multiple batts in one car without a problem.I'm a big car audio guy
SunlitComet
OBS Jedi-Do Good
It does not accomplish what is trying to be done when you simply wire them in parallel with just fuses in some cases. For you if you have multiple amps and you want a lot of running time then yes parallel the damn things but you should always have your audio batteries isolated in some way from the rest of the vehicle system unless you have a secondary charging system just for audio related power bank. Otherwise when running your radio amps a long time you can kill your pcm and starter power if they are just paralleled to the vehicles main battery without isolation.
barney91
mesa,az
What is it your trying to do by isolating the two batteries, also how would it hurt my pcm? I'm running all the batts together, and all are being charged by the same alt
SunlitComet
OBS Jedi-Do Good
By isolating batteries you can drain one with out touch the other. For Example you can have a starting battery and a deep cycle battery where you can runs say camp lights till the auxiliary battery is really low but the starting battery is left untouched with no drainage from using the auxiliary battery and they both get charged by the same alternator. If you setup works for you then good but it is not ideal. If the battery voltage to the PCM gets to low it will lose it fuel trim values and will have to relearn them. This may cause some performance issues for a while until the pcm has relearned them thru driving cycles.
saif najd
saif najd
True, do you recommend any US made isolator can stand around 200 amp?
saif najd
saif najd
Important question, what fuse should I use for the battery?
If I have an 85amp batteries and a 124amp alter?
Sent from my GT-I9505 using Tapatalk 2
SunlitComet
OBS Jedi-Do Good
You won't wnat to put a fuse battery to battery. It wont be isolated then. And if you wanted to bridge them for a power boost in engine starting, finding a fuse that can handle several hundred amp for starting an engine, is not practical and will likely be expensive.
saif najd
saif najd
I am thinking to go manual, marine manual switch! And find a place near the front bumper so I don't have to open the hood
qukon 95
just use the stinger 200 amp seloniod i've use these with no problems u can use the start only wire to trigger it.
saif najd
saif najd
Thank you, I will check it
saif najd
saif najd
Wow it looks great and I do trust it more than the other (ordering soon)
Thank you very much for pointing it
qukon 95
You do loose more amps and volts going through that isolator in heat that why they have
Heat sinks on it the solenoid you want have that issue.
vtxtexan
