VCIM Swap for Bluetooth Capability
Rockytfox
I have a 2008 Yukon Hybrid complete with DVD, NAV, etc. One of the features that I'd like to have is the capability to make/receive phone calls via bluetooth through the factory radio. I've done some research but need to confirm my thoughts before I proceed. My understanding is that VCIM part number: 20787107 will work with my truck. After having the dealer re-program, I'll be able to retain OnStar and will gain Bluetooth and the OnStar Link app capabilities.
Can anybody confirm this is the right part number: 20787107?
blkonblk
NYC
there are a few things that you have to do here. (this is what i did on my truck)
1. to have the option for remote link to work i bought a 2011+ vcim.
2. 2011+vcim has only two antenna connections in the back (prior ones had 3) so you have to buy a 'splitter',,,here is a link https://gmspecialservicetools.spx.co...s.aspx?id=5661. here is a pic of the oem splitter. you only need the splitter to the right of the pic not the piece on the left.
when you have that it allows onstar to send directions directly to your nav (if you have a 2011+nav)
I was not able to get onstar to connect my new vcim with my car (to much hassle) so i just called onstar and told them i just bought this car and would like to set up a new account (they think i drive a 2011 tahoe).
everything works smooth, onstar, remote link app, i can send nav directions from my phone to the nav system, i can call onstar and they send directions directly to my nav.
so as long as that part number they gave you is from a 2011 up tahoe your good to go. i would check ebay first(where i bought mine) just search for a 2011 up tahoe vcim bluetooth.
hope this helps
Rockytfox
Rockytfox
Thanks Bo. Are you able to use bluetooth? I'm assuming that's a yes...but just double checking.
Rockytfox
Rockytfox
Bo, do you have a part number for the VCIM?
IrishTR
San Antonio, TX
Sadly it will just be better imo to buy a nicer pioneer aftermarket unit with better bells and whistles than to try and just add half arsed bluetooth to the factory junk.
$702.69 for the radio and all the additonal cables to integrate with all factory controls and rse. Done! Amazon Prime
Pioneer AVHX8500BHS $489.85
PAC RP5G31 Aftermarket integration kit for our vehicle with Bose, Onstar & Steering wheel controls $108.67
PAC Rear Seat Entertainment integration $25.56
PAC USB Updater (incase I wanna update when PAC sends updates for the RP5G31 unit) $31.78
Parking Brake Override Bypass for Pioneer Unit $19.99
Pioneer Android Control Adapter $52.40
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Brooklyn hoe
I have also done this mod. I have a 2007 tahoe with the bose system with out navigation. I upgraded the radio to a Rosen with rear view camera and navigation. I later on did the upgrade with a 2010 vcim with no dealer visit.
I ordered the part from car-part.com part # 20829984. What your going to need to do is look up
chasis control computer then look for
communication -onstar with voice recognition.
This is what I did, when I got the unit i removed the old unit and installed the new one called onstar and updated my info onstar thinks I own a 2010 but it did not bother me. All the features work including remote link which stars your car open and close doors and informs you of how much gas u have etc. I hope this helps you out and good luck.
ledlow
Melbourne, FL
link does not work...
hope this helps
Albertayukon
Can anyone confirm the splitter you need for this? This is one of my planned mods and the above link does not work.
Ted
Rockytfox
Rockytfox
I just pulled the trigger on a 2010 VCIM 20829984. I don't think I'll need the splitter since it's a 2010 VCIM (just 2011+ VCIM's need the splitter??). Anyway, I'll post here once I have an update for ya!
bacin87
San Francisco, Ca
Thanks Brooklyn hoe for the part number I saw someone else on the forum did the 2010 VCIM swap but I didnt know the part number. For anyone that wants the remote link and Bluetooth to work you have to get a 2010 because its is the last year that uses the same factory harness as the 2007-2009 VCIM.
Rockytfox
Rockytfox
So where are people buying these vcims? I have had two orders cancelled now referring me to my local dealership which supposedly cannot order unless mine is defective.
blkonblk
NYC
ebay or junkyards orrrr car-parts.com like stated above
looks like car-part.com has one from a 2010 silverado for $150,,,thats cheap, someone grab it,,but make sure they send the bluetooth antenna also
Rockytfox
Rockytfox
Is the bluetooth antenna the same thing as the antenna on the roof or is it a separate antenna attached directly to the VCIM?
Rockytfox
Rockytfox
Bo, thanks so much for your help. The VCIM I found did not have the bluetooth antenna (pictured above) but I was able to find one online for $20 through ebay and Amazon. I appreciate your help and will update here once I've received the parts.
bacin87
San Francisco, Ca
Purchased a 2010 Silverado VCIM
Do any of you have instruction on how to install/remove? My VCIM died on my 2007 Tahoe and I found a used 2010 Silverado VCIM and need to know how to install.
vdesolution
