Rusty Door..
jstutz101
Kankakee, Il
Ive got a 2007 Yukon with 104,000 Miles. I noticed surface rust along the inside seam of the drivers side rear door. I then pulled back the rubber seal along the bottom the door and it has rust along the seam also. The odd thing is the other 3 doors are rust free. Has anyone else ran into this??
J
jstutz101
Kankakee, Il
Pics of said rust?
I wish I would of taken a few. Luckily my Yukon is white so I carfefully sanded and spray painted the affected areas (most of which are covered with the rubber weatherstrip) with glossy white Rustoleum. Actually came out looking pretty good. Not sure how long it will last.
It's odd how only one door is affected.
YuCanada
Nunavut, Canada
Your lucky it was on the inside. I'll take a pic of mine when I get out of the house today.. Starting to get bad. I need a paint job lol.
Goodinblack
I Like Tacos
Dirty South
I would be surprised david has a truck left at all......... in 10 years..
Canada.
Jk.
Lol
nai0248
I have a 2004 with 180K+ miles and have the same problem but only on the passenger front door. The rust is on the bottom part of the door near the seam where the outer shell is welded to the inner door shell.
I've asked around about this issue and the responses I have received are;
1) This problem is very common with Yukon/Tahoe.
I've discussed getting the door sanded and repainted and was basically told it wasn't worth it since the rust more than likely started on the inside and would reappear within a couple of years anyway.
2) This response from another friend seems more common sense to me. I live in the Midwest (Michigan) where they use various types of salt in the winter to clear the roads. These doors have a very good seal when they are closed. When driving in the slushy roads the salt gets up into the door through the seam. Regardless of washes, if the door is not used often (opening and closing) the salt remains in the seam and begins to corrode. The other doors without evidence of rust is because every time you slam the door shut, you are basically shaking the salt of the door.
I say this one makes sense because the one door that is has rust is the door that is used the least (very rarely). So now I randomly walk around, open and close the door just to be safe.
Of course these could all be wrong since I'm not a metalist/chemist or what ever. Maybe that one door just came from a different contractor that either used sub quality metal or improper welding.
My two cents at least.
J
jstutz101
Kankakee, Il
That theory would make sense in my case since its both back doors that have rust. So the only way to really fix the problem is new doors?? Yuk!
Thanks!!!
Jeff
Durobans
