Sub / amp help
YukonXL04
The Riverboat
Arlington, TX
Do you have the dual 4 ohm or single 4 ohm subs?
Also what is your budget, and do you have any preferred brands?
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
Oh yeah dual voice coil. So dual 4 ohm I guess how do I tell an no brand preference just not trying to break the bank
I'm not keeping this setup in my Tahoe it will go in my wife's Tahoe next year.
YukonXL04
The Riverboat
Arlington, TX
Well if its a dual voice coil then its a dual 4 ohm, the link you showed only shows single 4 ohm and dual 4 ohm as a option. Well if you want a mono amp then I would go with something in the 600-800 rms @ 1 ohm range. I would do 800 rms so you aren't pushing the amp to its max all the time and have a little bit of overhead room with power. Well are we talking $100, $150, $400? just give me a ballpark range
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
With three kids and the fact I just wrecked and and I am fixing outta pocket probably $200-$300 price range cheaper is better. As long as it's going to last.
As I stated above setup is going in my wife's Tahoe in January of next year. And she doesn't blast or listen to music really loud. I hope that helps.
YukonXL04
The Riverboat
Arlington, TX
to tell what ohms the subs are you can see in the bottom or anywhere around the magnet of the subs
you cant go wring with this amp
http://www.sonicelectronix.com/item_45519_Alpine-MRX-M55.html
ive had four of the earlier model before and love these amps..they send clean sound and are pretty compact and not to big
That amp will not work if it they are dual 4 ohm subs.
http://www.sonicelectronix.com/item_43782_MTX-TH650.1D.html
This would be a good choice if you would like to stick with the same brand MTX
http://www.sonicelectronix.com/item_69449_Orion-CO1200.1D.html
This would be a good cheaper option.
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
What's the difference between a mono amp and others? Sorry I speak. Motor not stereo. Thank you for the help also.
Sub
The Alpine amp posted by Josueh95 looks and specs almost identical to the top of the line JLAudio HD series, for less than half the price.
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
Got a new amp. Cheap. I'll let y'all know what it is later.
a4edwin
ny
Mono one channel no left or right signal. Used for subs
YukonXL04
The Riverboat
Arlington, TX
Mono amps are usually for subs because they are mostly class d, which is more efficient at converting power. Most multi channel amps are class ab which are usually around 20-40% less efficient which translates into more load on your electrical system.
alc5m
also more heat
but class a/b give a "truer" sound because most class d are digital, and it will actually cut off parts of the signal in increase the efficiency, i've see a/b mono amps before, but class d is seen 99% of the time
johnsonwillie199
