Vette66
Fresno, Ca
Vette66 does your rear wiper move with you use your Hi beams or blinker not. Full pass just a jingle?
Nope it does not move at all. On high beams or blinkers. Well unless I switch it on.
Well I can see the feedback on the output side for the 3rd brake light. Wondering if a 10 or 20 watt load resister would fix the issue. I will work on it more tomorrow.
I believe the 03-up are on the canbuss so it would monitor that there is sufficient load and allow the system to work properly. With the 02 at least it's all analog it either thinks the brake is on or doesn't to allow the cruise control to work. Apparently it is feeding back just enough for the cruise control to think the brake is depressed and will not activate. Will see as I said I will do a write up on it once the issue is resolved.
WHITEOUT
Dont Hate-Appreciate
Phoenix
I greased all my suspension and steering components yesterday. Holly $hit did they need to be done!! Took the Family up north to Sedona again, and was like driving a new vehicle. Have spaced out on doing it, never again. Every 6 months, at least, from now on.
godoy
utah
Wanna send me a pm where suspension has to be greased up at? Thanks!!!:)
Im a noob never done that before
JochenWoern
Sacramento, CA
I have those lights on my barn door. You have to trim them as well as moving the little control box. But I don't have any cruise control or feedback issues... even after hacking mine up lol.
Hope you figure out what is causing it. I do t want problems with mine. But the 3 stage blinker is pretty sweet. And yes they are very bright at night. So far I love them.
+1 - I AS WELL WOULD LIKE TO KNOW.
Many thanks in advance.
TailHook
Tattooed Millionaire
Arizona
Changed diff fluid, replaced trans output seal, replaced all shocks on the PPV this weekend...
Rivieraracing
I assume yours does Michael? If so, I'll have to drag up the thread on how to fix that, basically have to change out the ground on the front windshield wiper fluid reservoir for the squirters! I did mine years ago and completely fixed the problem, a pain to get to but for me well worth all the work!
YukonXL04
The Riverboat
Arlington, TX
Well I take back what I said about my cruise control not working. I know it works in the day time lol. But I tried this morning with the lights on and no cruise... what a bummer. Please let me know when you figure out the fix.
Thank you.
BlueTahoe2001
Charlotte, NC
Getting ready to order new bumper lights, Interior LED's, stainless braided brake lines, and all new energy suspension bushings for the front suspension.
TailHook
Arizona
How does it feel and ride with new shocks?
How many miles did you have on your truck?
Which brand SHOCKS did you use?
Rides MUCH better...
I recently bought this truck at auction from the Sacramento County Sheriff's Office with 124K. It was used for a mobile incident command vehicle, so it isn't all beat like the patrol units usually are.
The shocks I used were OE replacements for the Z56 suspension and are PPV specific, from what I understand. GM part numbers 88965334 (F) and 88965335 (R) from our friends at Rock Auto.
Vette66
Fresno, Ca
Thank you.
Will let you know going to tackle this today. It's annoying.
WHITEOUT
Phoenix
I guess term suspension I was using loosely. But I have zerk fittings on my sway bar bushings, and rear LCA bushings. I also run poly on most my suspension components, so use poly grease on them all. So I consider those suspension components, but all aftermarket so probably won't be related to most. And greased all front steering components that had zerk fittings.
Wasn't meant as a statement for others to need to do. My bad fellas. There aren't zerks on shocks, arms, springs bushings ect.... for stock suspension, that I'm aware of. So no worries
Vette66
Fresno, Ca
JochenWoern
Sacramento, CA
Many thanks.
---------- Post added at 11:48 PM ---------- Previous post was at 11:46 PM ----------
Changed the oil and gave it a nice wash before the rains hit this weekend.
No WHERE have you been Chauncey????? Glad to see you are back.
ASG-MikeS
