6 Inch suspension+3 inch level+3 inch body lift pics
EvontayeCannon
Alabama
I have an 03 Yukon 4x4, I'm planning on running a 6" Suspension+3" inch body+3" level within the next month, I was wondering does anyone have this setup or anything close to it? If so, can you please post pics.
01Konvict
Boats n Hoes
Raleigh/SML
Theres one 4x4 that I saw with that much lift but most are 2wd that high. Also the most you can really get is 2" level kit lift not 3". You get the suspension lift then add coil spacers and lift keys. With a 1.5" body lift you can clear 37s with suspension and level kit.
imi4tth3w
6" rcd set to 6" with 3" body lift
20x10 -24mm gunner 6 and 325 60 20 terra graps. no rubbing at all.
you can follow link in my sig for a lot more pics
Dillonv2008
Sac
6" suspension 3 body 35s on 20s
---------- Post added at 11:45 AM ---------- Previous post was at 11:44 AM ----------
Yukonboy2014
What lift/tire combo are you running in your OP picture? That looks just about perfect for me..
Yukonboy2014
oops, I am talking about EvontayeCannon's truck. I like yours too..that's awesome actually..
imi4tth3w
looks like 20x12's right?
just want everyone to realize the wider the wheel you run the smaller the tire you can fit. which is why he has to run a 6+3 to fit a 35 and i'm running just a 6" lift with my 20x12 and 33's and i still rub. had i chosen a different wheel, i could fit bigger tires. but thats not my style.
Dillonv2008
Sac
Ya 20x12. Yes I had some 16x9 before no so much off set on 37s but with the 20x12 -44 offset I wouldn't even be able to flex into a drive way
curbud
