:console: almost as bad as when I came home from vaca only to throw $1100 at the burb to fix a bum lifter :'(
08stockhoe
Can't afford 22s right now so, I plasti-dip my wheels. Still not sure how I feel about it ImageUploadedByTapatalk1373938291.970478.jpg
njracer
I washed it for the 1st time in weeks because of the weather and the upcoming forecast which called for no rain.
:rage: Now they are calling for rain later tonight.:rage:
Trx_Tahoe
BOLT Receiver Lock
I have been very curious about these locks for awhile, so I took the dive.
Now I just have to make sure I have a Hide-Away somewhere in the truck for those "just in case moments" I'm prone to.....
1) Bolt Hitch Lock
2) Keyed To My Ignition
3) Ready To Roll
Quick and Easy...
TRX
bigrhino
l.e.s manhattan,nyc
Check engine light came on,looked under the hood, my Airraid intake tube was loose. Tighted the clamps,drove around for 15 minutes,light out.
guy from norcal
wash and wax
Trx_Tahoe
New Phone Mount
Hello Everyone,
Thought I would post this, I had been looking for something that would not take away from my Tahoe clean look. I found this by mistake, but does the job real well....
Plus removes easily, base has some type of adhesive that lets you move as much as you want can be rewashed for consistent adhesion.
Brand: Bracketron
Model: Mi-T Grip
Price: $29.99 (Bestbuy In Store)
NathanJax
Vacation Nathan
Jax, Fl
Hello Everyone,
Brand: Braketron
Model: Mi-T Grip
Can you try to stick it to the side of the center console? Basically almost like where your knee hits the center console.
Thanks
Trx_Tahoe
As Requested....
Here you go....
NathanJax
Just as a note, make sure there's no Armor All on any surface you place this on....... In case you do, just wash with mild soap, let drive and it's adhesiveness returns.
This mount would work great on a FLAT back surface phone, our HTC One has a small curve and I have to make sure its all the way back on the mount.
Thanks,
JLR
NathanJax
Vacation Nathan
Jax, Fl
Thanks!
Jmat
Southern Cali
Just got back from two weeks in the California high desert. Also hit a couple of national parks & did some light off-roading, the Hoe was awesome through it all. Now it's time for a wash, polish & wax.
CHOO CHOO
BackPagePhil
Manheim, Pa
Forgot to post but got my front passengers side axle replaced, stainless brake lines installed, brake fluid flushed and replaced w/ amsoil brakefluid, oil change and trying out 15w/50 mobil 1 full synthetic oil. Brakes work AMAZING now w/ the new rotors and pads....
Hodmjstone
