Weird Tire Wearing and Weird Steering Response
mmeachem
Im having a problem with my truck that my neighborhood mechanic cant seem to fix
My steering response is horrible to the right but normal to the left. Also my front tires are wearing unevenly on the outside should as shown in the example pic below
I already tried replacing control arm and upper and lower joints and stuff as well as multiple alignments but after the alignment my front tires began wearing unevenly
I appreciate all help in advance
-Mike
chauncey0337
MLT, WA
Maybe you should have it checked out by another mechanic. Obviously something is not right.
kschumake83
Orefield, PA
If the truck seems to follow the ruts in the road too much, that sounds like a caster issue, but the tire wearing looks like a camber issue. Is there any feathering on the tires? as in is the end of one tread lug higher than the next. Was this vehicle ever in an accident? Did you look at the pitman arm, idler arm, and tie rod ends? Can you post a good picture of your tires?
angrysam
Have any of your alignment printouts? Seeing caster, camber, toe, thrust angle and SAI would really help.
Screwd up 6
Agreed...camber or to much toe would be my first thoughts. But if you have bad pitman or idler arm then you will also have wear due to the alignment having play. Have you taken it to anywhere else for an alignment since this place cant get it right?
imi4tth3w
front end parts checked is one. if the tires are already worn irregularly, you need to replace the tires. i was having alignment problems but narrowed it all down to the tires. all is good now.
mmeachem
mmeachem
No i don't because I've taken it to mieneke and pepboys now i'm going to order some moog idler and pitman arms and supports and get them installed and hopefully that will cure the problem
Thanks
-Mike
PUGLIA
Oklahoma
Check your wheel hub. Jack your front tires up. You can do them individually. Grab the top and bottom and see if you can get a wobble or play. If so your hub is bad. My tahoe used to skate as well. Easy test to see if that will solve the problem before you go down a rabbit hole with your front end. Not sayin the others don't need to be checked. But a hub will cause steering problems like following ruts or " skating"
-----PUGLIA-----
DCT
It's been a long time but wasn't there a dealer tsb for this? Possible recall? Call the dealer with your VIN.
johnsonwillie199
