A little WHOA! for the Hoe.
InTruckDesign
SW CT,
Finally found some time to do this. Fronts are SSBC 14" rotors with caliper relocation kit and Hawk ceramic pads, rear is stock disc with Hawk ceramic pads. All I can say is wow...major improvement..still not as good as my wife's Audi Q7 with Brembo's front/rear,but it alot closer now.
yooformula
Milwaukee, Wi.
Those look nice. Did you change over brake lines or fluid yet as well? I went with braided lines and ATE super blue for my car and I couldnt believe how well that worked in combination with the slotted rotors/hawk pads.
InTruckDesign
InTruckDesign
SW CT,
Lines were not recommended by SSBC as they have seen minimal improvement going to braided lines as the newer flexible rubber lines are reinforced with a braided fiber..fluid is a SSBC blend.
GalaxyBlackEsky
BlackedoutLT3
MD
I just did the same setup on my hoe two weeks ago. I love them and they def feel a lot better and plus they look good behind the 24's.
dre
what site did you order it from.........and do you still use the same calipars
05Yukon
Houston
What is the minimum size wheel you can run with that kit? What size wheel are you running?
ammar456
how much would you rate the improvement in stopping power?
Durobans
