Itching to go lower....
Bomba02
Want to close the wheel well gaps. This is my setup as of now.
Front
2 inch bell tech spindles
2 inch lower keys
Short bell tech sp shock
Bell tech front camber kit.
Stock bumps stop not modified
32 ground to fender lip keys are cranked up somewhat.
Rear
Tony's custom 6 inch springs
Djm hardware kit
Spohn panhard bar
Helper bags
Free travel mod
Short Bell tech sp shock
Isolators still in
32.5 ground to fender lip 5 psi in bags at the moment.
So I want to get down to to 30 or 31 with out changing tire size. Was wondering if 2500 keys and modify bump stops would be better then 2 inch keys with modify bump stops. Pretty sure not much I can do on the rear but I do have 3 inch djm springs which I'm thinking I can cut to get where I want to. There's a ton of good advice on here and tony already hooked me up with great parts. Do just looking for some advice thanks guys.
lowAZhoe
Resident GM Tech
Phoenix, AZ
the 2500 keys are the same as the 2" drop keys u have now. you would need to get the 3" djm lower control arms to go lower without ride quality suffering. the rear either cut some springs or bag it.
NathanJax
Vacation Nathan
Jax, Fl
I like your stance now. As Roger said, keys are the same.
Bomba02
Bomba02
Thanks guys. Good to know a about the 2500 keys that what I was wondering if same not. I don't mind the ride up front gonna decrank them a little and tirm and drill stock bump stops try that then if not get a set of z71 stops and mess with them. I'm kinda kicking my self should of just bagged rear from start thought 6 inch spring were gonna bring it done enough. Prob try cutting the other springs first see what that brings me.
Quick question on the bags if I went with like 2600 pancake bags those still good for towing? Got a boat I tow.
One last question off topic how do I upload larger photos with in the thread part?
Thanks
NORCAL SS
SUV SUSPENSION GURU
get the rear tbss bags 100 bucks and much better for load
Bomba02
Bomba02
Tony~ i know thses bags caused i had an 08 Tbss which i wish i kept. will those bag let me set height where I want or do they have to be at a certain point/psi to get a good ride out of them. Thanks for the info and just in case is that something you carry?
Bomba02
Bomba02
Good thought. Was on my mind I believe meangreen03 did a body drop using s10 mounts take it that's the same? Pros and cons to that tho? I do personally like the idea and not scared of doing it but does front bumper need to be lowered to work and roll pan is in my future so rear wouldn't be a problem. Slipping is it just the rubber you have don't you need to modify cup or use blazer ones? Are you interested in letting them go if I decide to go that way. Thanks.
slipping
Rosamond, CA
He is where I got the idea, but since I am going to bag Im not going to use.
http://www.tahoeyukonforum.com/forum/showthread.php?p=488370#post488370
Been a while since I read that thread, but I believe you have to cut the upper cups a little.
Ill save for when your ready for them
I have a thread somewhere - I sandblasted them and cleaned up nice.
Bomba02
Bomba02
Nice you have all 12? Are they poly or rubber? So you have no cups I could just get s10 blazer cups I believe the body drop thread said.
That would be and inch wish I could lower the rear an inch with springs I have now it rides good. I know I can adjust front down a inch things would be tuckin.
One last question slipping how'd you get your pic to be in the thread big cant figure it out thanks.
slipping
Rosamond, CA
All 12, stock rubber, has s10 cups(no need to cut). But i seem to be missing 2 of the lower cups (im wondering if the kids grabbed them) but i can always grab a couple from pull yard.
Big pics can use photobucket or similar pic service and it has an IMG link you can paste in
Sent from my SAMSUNG-SGH-I727 using Tapatalk 4 Beta
Bomba02
Bomba02
Thinking it might need to be done....so I'd just replace everything with what you got make sure nothing jammed or pinch and bam a inch lower... What are you thinking for loot?
slipping
Rosamond, CA
From the way I read his post, swap and go with the s10 mounts. Sent you a pm, Dont know if you can get or respond yet.
Bomba02
Bomba02
I got PM but I need 1 more post after this to be able to respond. But sounds good to me no rush tho just let me know when you get the other cups hopefully I be able to PM then and we can fill in the details. Thanks man.
slipping
Rosamond, CA
Cool deal homie
Durobans
