Alternator thoughts
EMF Audio
Spartanburg, SC
Anyone familiar with or concerned about this alternator?
http://www.amazon.com/Output-Altern...d=1369257549&sr=8-1&keywords=alternator+yukon
I need to replace mine.
As a general rule, any alternator under $200 won't do more than 150 amps reliably. If that is like most of the other ones like its claims and price, it will do that 250 amps at a very high RPM, won't gain anything at idle, and in a year or less it will die. They put a high output rotor in a stock case, call it high output and push it out the door cheap. The rest of it is not designed to take that power, and gets stressed, and fails.
619NJ
Go check out DC Power Engineering. Their alternators are second to none.
619 the Chef choppin' lips and deep-frying Mud Ducks in the Yellin' Yukon and I'm gone...
EMF Audio
Spartanburg, SC
That's what I've got on my truck, but if he doesn't need high output, no point in spending the extra money.
619NJ
You make a valid point. I'm ordering an xp 370 in the future to run some pretty awesome cb gear...very impressed with dc's tech behind their products
R
rollin23s
Austin, TX
I am getting an e fan and I have an audio logic 400 watt amp and jl audio 400 watt amp. I am also looking at some HIDs. I think I have a pretty decent current draw. I also plan on doing the big 3.
Sent from my Nexus 4 using Tapatalk 2
EMF Audio
Spartanburg, SC
That's not that much in the grand scheme of things. You have a 105 amp now right? A 145 amp reman will probably be OK. You can't go wrong with a high output, just may not be necessary. DC Power makes some basic ones for $300 that are 185 amp and stronger at idle I believe. That would certainly cover it.
alc5m
well even so with the 145 amp and the big three he'd be fine with that current draw, i've got the 145amp in mine stock wiring with a 1500watt rms amp and a 150watt 2 channel with hids and i just get a bit of dimming with the hits and nothing else
Drewphil
