Audio guys '02 subwoofer
ratled
ratled
Out on the claim
justirv
Thanks but I don't trust them as they are recommending 4 ohm spears to replace a 2 ohm speaker. I was told I would need an amp to power the
If you want a 2 ohm they probably have one. Also, a dual voice-coil 4 ohm wired in parallel will get you 2 ohms. For the '02 stock sub location, you want a sub designed for a sealed enclosure (non-ported) with a very small cavity requirement. I went with a JL 8" free-air (Vas ~ 0.3 cu/ft?), sealed the stock sub "box" as good as possible, and added a dedicated sub amp mounted on the floor under the middle 2nd row seat, with appropriate power and ground along with a farad or so capacitor. It's been several years, so my specs may be off.
NoReverseYukon
NE Wisconsin
This is what I bought :
justirv
Dive deeper in AI Mode
AI responses may include mistakes. Learn more
Sponsored products
  1. Klipsch Reference R-120SW Powered subwoofer
    $249.00
    Crutchfield
    Buy 2 get $130 off
    https://www.googleadservices.com/pa...oI-_5JGRAxWDVTABHZxWAU0Qwg8oAHoECAsQDQ&adurl=
    4.8(1k+)
    Shop now
    10 Inch Subwoofer 600 Watt PA DJ Sub Woofer Speaker 8Ohm
    $47.99
    5core.com
    By 12/9
    Shop now
    Bose 700 Subwoofer System - Black | 5GK525
    $899.00
    HP
    4.7(4k+)
    Free by 12/8
    Shop now
    40% OFF
    Pick up Fri
    Kenwood - Road Series 12" Single-Voice-Coil 4-Ohm Subwoofer - Black
    $35.99$60
    Best Buy
    4.5(601)
    1.6 mi · Closed
    Shop now
    Sale
    CT Sounds Dual 12” 2600W Complete Bass Package with Loaded Subwoofer Box and Amplifier
    $487.48$650
    CT Sounds
    4.8(203)
    Free 2-day
    Shop now
    Sale
    SVS SB-3000 Powered subwoofer with app control - Piano Gloss Black
    $1,099.99
    Crutchfield
    4.9(792)
    Free 2-day
    Shop now
    Electro-Voice ELX200-18SP 18-inch Powered Subwoofer
    $1,099.00
    Sweetwater
    4.8(316)
    Free 3-day
    Shop now
    Bowers & Wilkins ASW608 Compact powered subwoofer - Black
    $700.00
    Crutchfield
    4.8(714)
    Free 2-day
    Shop now
    Sale
    Pick up Fri
    JBL - Stage 220P 12-Inch Powered Subwoofer - Espresso
    $399.95$660
    Best Buy
    4.6(68)
    1.6 mi · Closed
    Shop now
    Sale
    Polk Signature Elite ES12 12" powered subwoofer
    $585.00$899
    Crutchfield
    4.6(10)
    Free 2-day
    Shop now
    40% OFF
    JBL - Stage 200P 10-Inch Powered Subwoofer - Espresso
    $329.95$550
    Best Buy
    4.8(90)
    Free by 12/5
    Shop now
    49% OFF
    Klipsch - Reference Series 12" 400W Powered Subwoofer - Black
    $325.49$650
    Best Buy
    4.8(555)
    Free by 12/5
    Shop now
    Bowers & Wilkins DB4S Powered subwoofer - Rosenut
    $2,900.00
    Crutchfield
    4.8(249)
    Free 2-day
    Shop now
    Sale
    Polk Monitor XT12 12" powered subwoofer
    $319.00$399
    Crutchfield
    4.7(59)
    Free
    Shop now
    Refine your search
    used hsu subwoofer for sale
    best home theater subwoofer
    best subwoofers
    best 12 inch subwoofer
Sigberg Audio
https://www.sigbergaudio.com
Subwoofer specifications explained
Feb 19, 2021 — Subwoofer specs include frequency response, SPL/dB, driver type/size, cabinet type (sealed/ported), and power ratings.
People also ask
What are the specs on a subwoofer?
What's better, a 2 ohm or 4 ohm subwoofer?
AI Overview
+13
Neither is universally better; a 2-ohm subwoofer is louder but requires more power and can generate more heat, while a 4-ohm subwoofer provides cleaner sound and better system reliability by drawing less current. The best choice depends on your priorities and your amplifier's specifications, as a mismatched impedance can strain or damage the amplifier.
This video explains the difference between 2-ohm and 4-ohm subwoofers:
1m
Mathias Does Tech
YouTube · Jan 3, 2025
2-ohm subwoofer
  • Pros:
    • Louder volume due to lower resistance allowing more current to pass through.
    • Ideal for those who want maximum bass output.
  • Cons:
    • Requires more power from the amplifier and can strain it, potentially causing distortion or damage if not matched correctly.
    • Generates more heat, which can affect long-term stability.
This video explains how to choose the right ohm subwoofer for your amp:
55s
Five Star Car Stereo
YouTube · Jul 12, 2016
4-ohm subwoofer
  • Pros:
    • Provides cleaner sound quality and better system reliability.
    • Dissipates heat better and runs more consistently.
    • Works well with most factory audio systems.
  • Cons:
    • Less powerful output compared to a 2-ohm subwoofer.
    • Requires an amplifier that can handle the increased sound and volume capacity to get the most out of it.
How to choose
  • Prioritize volume:
    Choose a 2-ohm subwoofer if your main goal is the loudest possible bass, and you have an amplifier that can handle the extra current draw.
  • Prioritize sound quality and compatibility:
    Choose a 4-ohm subwoofer if you prefer cleaner sound and are looking for a more reliable, stable system, especially if you are using a factory amplifier.
  • Check your amplifier's specifications:
    Always match your subwoofer's impedance to your amplifier's capabilities to prevent overheating or damage. Your amplifier's manual will state the impedance it's designed to handle for maximum power output.
If you want a 2 ohm they probably have one. Also, a dual voice-coil 4 ohm wired in parallel will get you 2 ohms. For the '02 stock sub location, you want a sub designed for a sealed enclosure (non-ported) with a very small cavity requirement. I went with a J...
Turns out it is a JBL 8" (no spec on details), driven by a Blaupunkt PCA2120 dedicated amp.
waveryd
IL
Pioneer, Kicker, Rockford Fosgate, MB Quart and JL Audio all offer 2 ohm capable 8" shallow mount subwoofer drivers for sealed boxes sized less than .5 cu. ft. There might be some slight modifications or trimming involved but solutions are out there. I just researched this yesterday while planning an audio refit for my Yukon XL.
And as stated above I would stay away from the cheaper brands. Quality of those is hit or miss at best. In my opinion it is better to spend $150 than waste $50. I install a lot of marine systems and have this conversation frequently.
