01 Tahoe 2wd
slick_oo
I want to lower my truck....I bought the Eibach lowering kit...keys for front and 3" drop springs for rear...
Did anyone use this setup before how is it???
Anything else I would need???
I tow my car this this I use a car hauler..I wanted to use 24" or 22"
I wanted to use air shocks in the rear so I can add air to adjust load
What do you think?
Alex33
Generally speaking, drop keys create a worse ride than drop spindles.
LOWPRO24Z
Cali
I've got the same Eibach kit on my 04 & I would suggest going w/ another kit honestly. The truck rides pretty rough, although I've had the kit for a long time now & I probably need new shocks in the front also.
Go with spindles like the others suggested.
lowAZhoe
Resident GM Tech
Phoenix, AZ
drop keys make your ride quality suffer. since spindles only move the wheel hub up the front end is basically stock geometry and stock length shocks. go with belltech sp shocks all around or bilsteins. i have belltech and ride is good. use helper bags in the rear springs for towing.
S
slick_oo
are the air shocks no good?
Do i need to get rear shock re-locator?
S
slick_oo
Im running 24s with 395/35rR24
Bentley95
