Is there a +1 size from 265/65-18 Z71 tires?
Mighty Hd
Florida
Since I ordered a 2013 Z71 tahoe 4wd today, the tires are going to have to be replaced -- the goodyear street tires that the new ones come with suck. The Bridgestone Duelers were far superior aesthetically speaking.
Will a 275/65r18 fit without a lift? I am considering a 2" lift but am really on the fence.
Thanks
Mighty Hd.
njracer
Thanks
Mighty Hd.
I thought the Z71 package came with A/T tires??
Zed 71
Pacific NW
Yeah I thought that was the case also. I was just at the local dealership and all the new Z71s had ATs.
IMO 275/65/18s on stock wheels will be really close, not much room with the Z71 front valance caps. Level kits do not alleviate the rubbing issue. It might be ok when installed, but once you start flexing the suspension it will rub at full lock with larger tires. It really isn't a big deal to trim, but I know it is hard to cut up a new truck.
M
Mighty Hd
Florida
The z71 tahoes here have Goodyear SR-A tires that look more like a touring tire thn an all terrain.
I was going to put on BFG AT but a set of 275's. I am also considering a leveling kit, but styling with a 265 or 275.
Thoughts?
STORMIN08
I would look a little harder at the truck, when I ordered mine ,,,,there was three levels of Z71 , and one of them was a shock package for 2wd.....then a 4x4 with shocks and skids, and mine.....full tow package, with oil and trans cooler along with the suspension.
M
Mighty Hd
Florida
The one I ordered (and on the lot but not the color I wanted) has:
Towing
Luxury package
4x4
Z71
Sun/Destination package
Integrated trailer brake controller
2nd row bench
The ones on the lots do not have the sun/destination, 2nd row bench or the trailer brake controller.
All of the ones that have seen anywhere all have the Goodyear street tires...........???? Does anyone have a 2013 with the bridgestones?
MSBlackZ
Mississippi
I honestly dont know what the largest size tire you can fit stock but i'm interest to find out!
M
Mighty Hd
Florida
It's looking like I can fit a 275/65r18 without a lift from what I have been finding on the forum.
I just can't find any photos.
MSBlackZ
Mississippi
I'm sure someone has done it. If you plan on going this route please post some pics!
---------- Post added at 04:15 PM ---------- Previous post was at 03:21 PM ----------
Not trying to take over post... But what about 265/70/18 it would add 1" of tire. This is what I would like to do if possible.
tights24
Sorry, I'm new to my truck and I have a 2wd, but I can't believe that GM would have a 4wd full size truck that couldn't fit 32's on it bone stock. I would have guessed in all honesty that you could go up to a 275/70 without issue, but it looks like that is way wrong after reading some other posts. Wow. Good luck with your search and your tire purchase. FWIW, I have stock 275/55/20's on my truck which equate to almost 32". I would think in a 4wd version I would have more clearance than what I have now.....
M
Mighty Hd
Florida
I wonder if just doing a leveling kit and factory size tires would look stupid??
Zed 71
Pacific NW
The Z71s "offroad" package has less room at the front wheel wells because of the front bumper caps. Yeah go figure :wtf2:.
I ran that way for a little while. It looked funny but not that bad.
M
Mighty Hd
Florida
Is there a kit to level just the front without having a cali lean? With most kits, it appears that the rear must be raised 1" as well so it levels out.
InTruckDesign
SW CT,
On a Z71 go with a 2" front spacer and it will be perfect. This is 2" front level with 18x9 XD Addicts, STOCK tires.
M
Mighty Hd
Florida
Nice! That's exactly what I'm looking for.
What 2" lift did you go with & tires?
InTruckDesign
SW CT,
Level kit is from Zone, bottom mount...tires are stock I think Bridgestone. All we did was level it, add the Addicts, tint and colormatched bowties...very simple yet set it apart.
STORMIN08
I found through some searches, that the lift spacer is roughly 1/2 the amount of lift.....I have a lower spacer that is 1", this should be 2" lift.
I do not want the cali lean so I plan to shave it down to 3/4" thick.
Gr8white
265/70/18 is what I run without a lift on an 09 Z71.
STORMIN08
please post some pics......
I am currently looking at tires, as mine a have 33000 miles....
I am looking at 3 options.....
1. 285 /65 /18
2. 275 /65 /18
3. 275 /70 /28
my plans are to run a 2" front level only...if it sags, I will look for a 1" rear. I already have the 2" front, so I am using it.
any one with some accurate feed back please chime in.....I will also be running stock wheels.
Gr8white
Now that I think about it...Im pretty sure I'm running 275/65/18's. fwiw here are a few pics. I'll verify size shortly.ImageUploadedByTapatalk1367277634.928437.jpg
ImageUploadedByTapatalk1367277655.226142.jpgImageUploadedByTapatalk1367277672.359828.jpg
No lift/stock rims...fender liners were pulled slightly for clearance and I believe they may have trimmed lower valance some. Tire shop used hd zip ties to pull liners and hold in place. I think I'm going to remove zip ties and use a heat gun to manipulate the plastic to clean it up a little.
Korbin_A
