Interior LED installation....
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
For those of you who have done this, how do I remove the lens from the headliner housing? I don't want to begin prying in the wrong spots...
1sikyukon
SFV, CA
If you look very closely at that lense you will see that their are slips in it that you can fit a knife or even a flat head screw driver to pop it right out. It is very simple, no need for force if you use something that fits into that slip it should pop right out.
UofMZ71
make sure you do the correct side for the middle and rear. They both have lenses that you pry one side, just slightly, and the other side is kind of a hinge. Once you figure out the correct side its really easy and it will just fall right out. Install and repeat :)
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
six dome lights? 2 in the roof and 4 doors?
Thanks for the info. Made this simple.
Actually, the NNBS have two dome lights per row in the headliner. I'm not sure what the NBS application will be though...
snowjay
I used a very small jewelers screwdriver to get them out. I would pry on one side a bit to free it and then do the other side and it would come lose. The hardest was the map lights. IIRC you want to pry on the side closest to the windshield. Just go slow and it's not that bad. Worst thing that can happen is you crack a lens which can easily be replaced. Not really what you want to have happen but it's not the end of the world if it does.
OT... this is the screwdriver set I use for things like this. It comes in so handy for projects like these.
http://www.amazon.com/Tool-135-0916...ref=sr_1_1?ie=UTF8&s=hi&qid=1253140296&sr=8-1
jack24
Hey thanks alot for tip. Also thanks for the amazon link:)
SabrToothSqrl
dim
how does it look? I kinda like the 'warm glow' of incadecent (i can't spell) lights on some things.. LED on other...
do the LEDs dim before they turn off like the regular ones?
I have LED tails, thinking about LED turns in the front and or LED on the licence plate
I need a smoke cover for mine... legal or not I want it to blend in w/the black :)
Fast55
Ventura County USA
LED interior lights still dim before going out just like stock. They look nothing like stock incandescent bulbs. Even the 5K bulbs I used are very "white", maybe even slightly blue, and are not much brighter than stock. The 6K bulbs are too "blue" for my tastes. This is the 9 LED bulb that is still the same shape and size as the stock bulb. The larger "panel type" with 12, 15, or even 20 LED's are a lot brighter.
e-dub75
USA
Any photos of the transformation iwaslowr? This is a project I've always wanted to do. If you say it makes a difference and looks hella nice then I'm ordering my six interior.
yukon07Artic
Dirty South ATL
iwaslowr what kinda tint did you do? is it 20% all around? or is that photo photoshopped? looks clean as hell, if its 20% did any cops ever give you a hard time on the tint?
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
It was 50% on windshield with an upper and lower brow of 5%, 5% on the front doors, and 15% on the remaining rear windows... I got pulled over a few times but the tint was never mentioned...
---------- Post added at 09:02 AM ---------- Previous post was at 09:01 AM ----------
I never go around to completing this mod before the truck was stolen, only the licence plate lights had been installed...
CKendrick
