iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
For those of you who have done this, how do I remove the lens from the headliner housing? I don't want to begin prying in the wrong spots...
what LED bulb are you using? any part #s?
I used these for the plate bulbs:
http://www.v-leds.com/Exterior-LED/...-LED/2-HID-WHITE-HIGH-POWER-p4481133-1-2.html
and these for the map/domes:
http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/HID-WHITE-M-SMT-20-LED-p5108588-1-2.html
I got mine from eBay user vleds
(six) 211_20_W for interior dome lights
(one) 194_HP_W for license plate light set of two
six dome lights? 2 in the roof and 4 doors?
Thanks for the info. Made this simple.
If you look very closely at that lense you will see that their are slips in it that you can fit a knife or even a flat head screw driver to pop it right out. It is very simple, no need for force if you use something that fits into that slip it should pop right out.
I used a very small jewelers screwdriver to get them out. I would pry on one side a bit to free it and then do the other side and it would come lose. The hardest was the map lights. IIRC you want to pry on the side closest to the windshield. Just go slow and it's not that bad. Worst thing that can happen is you crack a lens which can easily be replaced. Not really what you want to have happen but it's not the end of the world if it does.
OT... this is the screwdriver set I use for things like this. It comes in so handy for projects like these.
http://www.amazon.com/Tool-135-0916...ref=sr_1_1?ie=UTF8&s=hi&qid=1253140296&sr=8-1
Hey thanks alot for tip. Also thanks for the amazon link![]()
how does it look? I kinda like the 'warm glow' of incadecent (i can't spell) lights on some things.. LED on other...
do the LEDs dim before they turn off like the regular ones?
I have LED tails, thinking about LED turns in the front and or LED on the licence plate
I need a smoke cover for mine... legal or not I want it to blend in w/the black![]()
Actually, the NNBS have two dome lights per row in the headliner. I'm not sure what the NBS application will be though...
Any photos of the transformation iwaslowr? This is a project I've always wanted to do. If you say it makes a difference and looks hella nice then I'm ordering my six interior.
