Ordered my 6.0
JKmotorsports
JKmotorsports
Austin, TX
Inj A fuse is the supply voltage for bank 1 (dr side), and Inj B fuse is the supply voltage for bank 2. Both of these are in the underhood fuse block. When u get a chance, double check those and also make sure the connectors at the pcm are fully seated. And get back to me on which inj are not firing whenever u get a chance. If u can narrow down exactly which injectors, then I can narrow down which wire(s), harness, dist point, etc. Thnx bro.
BOSS
The People's A D M I N
Dallas
You know entirely too much about these trucks Yoda.
B
AtomicHoe094
Atomichoe094
cleveland, OH
B
you watch alot of movies? or have a really good memory??
i saw you called someone a grasshoppa before (actually i think me lol) now yoda.. lol i probably didnt catch the other ones lol
JennaBear
Resident Ninja
San Diego, CA
I am betting all the money in my purse, that it is not the injectors....have you run a compression test and checked the plugs?
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
im betting all the money in my bank account he should just give the engine to me since its such a problem. :D :D :p
JKmotorsports
JKmotorsports
Austin, TX
I did a compression check when I first brought home the motor. Going to do another when I get there. Plugs are good.
I've ruled out a lot of stuff and only have a few more things to check that will be easier once I get back to BOSS' crib.
And in the end........I will win. No matter how far away that is...
Max
Mile High
Denver
Probably a multimeter. Hammers don't work well on delicate electronics, I've tried.
JKmotorsports
JKmotorsports
Austin, TX
haha, yea, I've tried that a couple times in the past and learned a hammer isnt good for diagnosing electronics, but it does help relieve some anger.
tsb09000
Thread Killer
Save the anger for the poor poor rear tires when you get that beast going again!!
With a video camera somewhere near by! :D
BOSS
Dallas
Well Gdamn. Here's your first...he's not even here yet :rocking:
[yt]-gii3T2-1ME[/yt]
Think he's gunna be smiling?
B O S S
COTahoeLS
Senior Member
Colorado Springs, CO
Hell ******* yes!! Can you do a video of a complete walk around of his truck? I like some of the things on the exterior.
What was the diagnostics??
BOSS
Dallas
Not 100% sure what the diagnosis is to be honest, I think it's a faulty injector harness perhaps. Among many other things so far.... late late last night or early this morning I replaced the plugs, tested all the injectors AGAIN, pulled a 3 cyl misfire so I put a noid lite on it. It blinked and blinked and never skipped a beat, so I went to remove it and discovered when I pull on the wire I lost signal. So I tightened up the #3 injector wires into the plastic piece and plugged it back into the injector. Bam.
Worked my butt Day and Night I tell ya....I'd be gdamn'd if I didn't fix this thing in my garage. I'm going to pick up my blood pressure medication and have a drink.
B O S S
COTahoeLS
Senior Member
You definitely get props from me bro! That shit would drive me nuts for sure. I've done some nasty things back in my day destroying drywall in the garage from throwing tools.
justinakay79
