would you buy a 93 blazer with 300,000 miles ?
19 tahoe 97
I just found a 93 blazer on craigslist for $1000 obo with 300k miles. according to the ad it has very little rust which is unheard of in NE and it just passed inspection in november. It comes with 2 sets of rims with tires. Unfortunately it will need gas lines. Would you buy and drive something with 300k? it's a 350 not a diesel.
If its mechanically sound and has a solid body I'd have no problem driving a 300k mile blazer. I'd definitely give it a good look over!
19 tahoe 97
19 tahoe 97
This is what I thought initially but I just wanted to make sure that I wasn't being overconfident in a truck this old. thanks
Donnie Yukonie
Yates Caretaker
To be honest at 300k miles it probably had a lot of things already replaced to get to that kind of miles I.E trans , Alt, water pump ect…. If it checks out SCOOP IT UP
Chris2388
I was suppose to go look at that one. The only thing that drew me away was the 93 interior that I hate.
19 tahoe 97
19 tahoe 97
yea, plus it's a red interior. but for a grand it seems like a good deal. where are you from?
19Yukon97
Hate that nasty red interior. And the blue also. I would look at it. 1,000$ is cheap if its a solid frame. Scoop it up! You can always put some money into the motor and trans if its bad. I wouldnt get something that isnt running or the transmission is already dead in it.
19 tahoe 97
19 tahoe 97
I will definitely check out the frame if I go to look at it as I have a 1'' x 12'' hole in each of the frame rails on my 97 tahoe.
Chris2388
Im from the Stoughton/Randolph MA area. Yourself??
I can patch up that 1" by 12" hole in your frame.
19 tahoe 97
19 tahoe 97
I'm right on the mansfield/norton line, and because of that, my street never gets plowed.
I might have to take up your offer on that patch if I don't end up getting this truck. thanks
Gzes
the drifting 2dr
Wichita tx
Get it! Imo i like my 94 dash but yea the tbi is a monster for towing and i would get it if its not rotted
Chris2388
I would be glad to help. But I say get the truck so you have 2. The blazers interior is kinda dated but its a 2dr:shocked: so its a catch 22.
You'll have to excuse gzes. He often times just vomits out random thoughts that rarely make sense and even more rarely are actually factual.
19 tahoe 97
19 tahoe 97
I called the guy and he said everything works well and it doesn't need any work except gas lines. I think I will go look at it tomorrow afternoon if I get a chance.
As much as I would like to keep both of them I only have the space for 1 so we'll see what happens.
Gzes
the drifting 2dr
Wichita tx
Random? 92-94 = same dash and i have towed 11,000 ibs of brick in my 2dr so the tbi is pretty good for towing. The trams does well aswell
retorq
Kingman AZ
Did you just say the 92-94 4L60E "trams" did well towing 11K of bricks?? ***** getting deep in there.
992dr
Eastern N.C.
Miles are just numbers nothing more. As long as it has been properly maintained is all that matters. Go through it with a fine toothed comb, check all fluids. Dont get all excited if it has clean fluids, expect to replace everything.
If you do get it, the first thing you should consider is flushing the entire fuel system including the tank, especially if it needs new fuel lines.
Grab a new fuel pump while youre at it to and dont forget a fuel filter.
Hey Chris,
I grew up in Randolph, MA.
KPOD
Michigan
Maybe he means once it's been rebuilt with a stage 10 kit, and had a 24V Cummins swap done, and the frame reinforced with titanium :laughing1:
_Dylan_
STAY FROSTY
So its good for towing 11,000 pounds just because it can move it?
Sorry, but if it was "good for towing" it would have way better brakes, a trailer brake controller, better suspension, stronger frame and hitch. You are going to kill someone towing 11,000 pounds.
As for the OP, I wouldn't buy it if I was going to drive it everyday. You will have to start replacing every part on the truck when the mileage gets that high. It would make a good project vehicle or something to go beat up out in the woods.
Drewphil
