GFDI! Broken rear heater... maybe
tybardy
everyone needs a Hoe
Gilbert Arizona
My front heater works just fine... but the rear heat blows cold. Is there some sort of actuator or something that is not switching over? Obviously the heater coils are working just fine and the blowers are actually blowing... just not hot
yooformula
Milwaukee, Wi.
from what I have read and plan on doing, it sounds like the actuator in the rear cargo area, pass side. Sounds like the blending door or w/e is stuck in the cold position. I have the same issue with mine, was intermittent now just blows cold constantly yet the heater core has hot lines on both sides.
link...http://www.fullsizechevy.com/forums...e-rear-air-has-no-heat-just-blowing-cold.html
road1will
pretty pretty good
Johns Creek, Georgia
Yea, the blending door is most likely stuck. I think its pretty common on these trucks. My dads old '04 suburban had it happen twice.
nicegy31
I have the same problem. I found that the part that the actuatior control was broken I had to changed the upper console now I have to do some more troubleshooting. Both actuators are not working. I swapped them and neither one is moving. Does anyone have the write up on what wire has voltage on them I seen it in the forum before but can not find it now?
vatahoelt
NoVa
after installing the new actuators, did you do the re-learn process?
did you check the fuse under the hood to make sure it was still good?
even with them not working properly, it's uncommon for them to not move at all.
kses123
kses123
Raleigh, NC
Did you update to the new actuator controller module? It is a little computer that has updated software in it to prevent failures.
kses123
kses123
Raleigh, NC
I don't remember there being a re-learn process for the rear. My actuator was stuck on cold. I found the GM bulletin online about how to fix it. Replace the actuator as well as the little control box. I got them both on Amazon. I had the battery unhooked and installed everything. When I hooked it up, I didn't touch anything. It ran a little self-test then everything was working normally again.
03Dnasty
Kansas, Rock Chalk!!!
Yeah, I took my rear panel off today and found that the one actuator is stuck on cold. I can manually turn it to heat and it'll work. The cheapest I found on Amazon.com was $70 which is better than the local parts store wanting $116!
stormin
Toronto
mine now works....
I was reading somewhere... that if you disconnect the battery... and let it sit for a few mins.. then reconnect battery... the system or the control for the actuator... can .. "relearn"...
so that's what I did ...and I now have heat once again in the back of the tahoe!
good luck all
take care
NB
03Dnasty
Must be nice! Mine is shot and I don't want to spend the money to get a new one so I just rigged it up and set on heat for now.
03z71chevy
Buford, GA
Here is the proper re-learn procedure for the actuators. I did this when I replaced my passenger side actuator (be glad you don't need to replace that one). This website also has the procedure to replace all of the front actuators.
http://www.sparkys-answers.com/2011/08/hvac-actuator-recalibration-procedure.html
---------- Post added at 02:01 PM ---------- Previous post was at 01:58 PM ----------
Oh and my rear actuator has been stuck on cold since I bought it. Not as big of a deal for me since mine is stuck on cold. I can live with that.
D Rollins
