Adding Power Running Boards to Non-Factory Equipped Model
Fearz
Houston
great points....I think the only way I would know that is trial and error
another question, do either of you know if on the factory equipped models when you open JUST thcould door, do the steps come down? the way the AMP instructions state you only tap into one wire per side per up/down...I would think this would mean they only open when the front doors are open and not if just the back was open....unless the signal they tap into represents the whole side of the vehicle
I think those wires represent the whole side cause the amp guide says blk/gry drivers Side and wht/tan passenger Side. I didn't see a phone number on their site, but im sure you can find out quick.
Edit: plus it would make sense to have the whole side one wire so no matter which door opened the steps would deploy. Now im not sure about that as i know the screen tells you which door is open so each door could be individual or it could just read for a break in the signal to tell which door is open.
yates ™
Resident Apple hater
Iowa
It should drop down when any door is opened but I have not looked at the amp wiring to tell you how it works.
baggedlvintegra
baggedlvintegra
Fort Worth, TX
I think you may be right Fearz with regards to just reading a break and it's probly a single signal. Atleast it seems to have to be the way the AMP steps operate.
another idea on your comment earlier....you questioned if the door open / door closed signal stayed on the whole time the motors would be closing / opening, but I thought the point of the relay was to hold constant power and the signal just allow that to flow.
ie when the signal hits the relay it is a one time "pop" if you will that starts the clock, then the relay provides full power for the designated time following the "pop"...if that makes sense
baggedlvintegra
baggedlvintegra
Fort Worth, TX
So I put the this diagram together, I'm thinking this has a pretty good shot at retro-fitting the power running boards that would retain the factory operation. Let me know your thoughts.....also I'm not electronically versed enough to know exactly what relays I need to pull this off, suggestions would be appreciated. I've found this one that seems like it could work... http://www.ebay.com/itm/330773555670?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Pachanga02
Ny
Were you able to install and have the boards work as stock? I was thinking about getting a set of these and trying to get them to work on my NBS Denali. Instead I went with 08 NNBS escalade running boards.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
its the same when trying to program Power folding mirrors into a truck that didnt come with that option from the factory.
baggedlvintegra
baggedlvintegra
Fort Worth, TX
I haven't received the boards yet but I will keep everbody posted when I do....I think in principle I have figured out how to make them work but I really need some help finding a relay that will perform the desired function. Seeking an electrical guru!
Pachanga02
Ny
In my case I have an 02 without power fold. So to have that I think I read I need the bcm from a newer with the power fold option. When I was looking into swapping the power boards I asked my electrical guy and he said he would connect them using a switch to manually do it from the inside or splice into the puddle lamps since they turn on when the doors open to have the boards fold out. I thought it was a little too complicated and didn't go with them. But if I lower my truck in the spring I think it would look killer with the power boards
Regency
How are you going to add the button that makes them down all the time or up all the time near where the foot pedal adjusters are?
baggedlvintegra
baggedlvintegra
Fort Worth, TX
I won't be able to make them down all the time (without the door just staying open) but I will have a disable switch in the cab that will make them stay up if need be. Honestly I can't think of a situation where I would need to leave them down and is the least of my concerns
THE YETI
Director of Operations
South FL
The OEM power steps cannot stay down all the time. You can only make them stay up all the time.
baggedlvintegra
baggedlvintegra
Fort Worth, TX
So after extensive research, getting discussion going on the12 volt (super informative), reading over AMP and Bestop install instructions, etc. I have determined that for sure without a doubt these can be installed to work just like factory functionality, it's just a matter of two options:
1) "Design" a Controller module using timed relays and PAC TR-7 modules, plotting a wiring scheme, soldering diodes, running all the wires and testing it. Should work but not 100% confirmed without doing it all. Estimated cost $110 for all parts, LABOR intensive
2) Buy the AMP Power Step Control Module and Wiring Harness - Estimated cost $200, cleaner install NO design work, also the harness includes the LED lighting over the board so that is a + I guess
So the catch, the only issue with #2 is after talking to AMP Tech Support their module is programmed to run the motor for 5 seconds (the time it takes to extend / retract the AMP steps) but from my calculations it only takes 2-3 seconds tops for the OEM steps to reach full extend / full retract. Meaning the motors would run for 2 full seconds after the arms were maxed out. I'm concerned this 2 seconds of continually power to the motors will wear the motors out much sooner than they should.
Thoughts? Is my thinking on the 2 seconds unrealistic, and I shouldn't worry about it?
THE YETI
South FL
I can tell you that ours went up and down faster than 5 seconds. That seems long.
Very good info tho!!
Modded
That Guy
I thought the GM boards are made by AMP Research?
CarToons
What about using a power window module from an alarm add on? They sense the current when a window closes all the way and shut off. Otherwise work just like reversing polarity relays. I'm pretty sure you can buy them for about $50 and should protect the steps more than some sort of a timer.
justinakay79
