Help! Both the Stabilitrak/Traction Control and ABS lights are lit up on my DIC!
felixgun
Lafayette, LA
Ok, so a wheel weight fell off one of my rims which caused my avalanche to shake violently on the highway when going over 60mph. So I went to a nearby Discount Tire Direct and had them re-balance all 4 wheels/tires. I was due for a rotation on the Toyo MT's so I figured it'd be a good time to go. Well when they were done, my car drives super smooth now BUT the Stabilitrak/Traction Control light and ABS light are both lit up on the DIC and reads "Traction Control Off" and "Stabilitrak Off".
I brought it up to the guy who handed me my keys after and he said "drive about 20 miles and if it's still on come back tomorrow". Well I'm working a lot and by the time I get off they are closed. I had to leave work early to go get it done this time so it's not exactly easy for me to just leave work. Any of you guys have this issue when balancing or rotating their rims/tires?? I'm hoping something just got unplugged or something because I don't feel any difference in ride quality and the brakes work just fine.
Modded
That Guy
When they jacked up your car on the frame lift the wheels and tires probably sagged down far enough for your rear hub speed sensors to come disconnected from the connector on to of the frame rail.
Find the little wire like things coming from your rear rotor area and follow them to the frame rail and ensure they are plugged in.
You can also do the same for the fronts if that does not work, but it is more likely to be the rear in your case.
2011Tahoe
Wa Coast
My guess would be that you have a hub assembly going out. Does it sound rough or like your driving on super swamper bogger tires? Also if you swerve to the right or the left does it get better or worse. Hub assembly are a extremely common problem on all silverados. Have them or your reg mechanic jack it up under the control arm, grab the top and bottom of the tire and see if there is movement upward/inward. If that makes sense.
I have never seen a wheel weight do that kind of damage. You live in Denver right? If so take it to one of those new les Schwab tire locations they will do a free front end inspection for you.
Donovan
RIO GRANDE VALLEY, TX
I have seen the abs connection get damaged on the front end before on silverados. It connects to the top rear part of the hub not sure if it the same on yours.
felixgun
felixgun
Lafayette, LA
Ok ill look for this today. Thanks modded!
---------- Post added at 10:30 AM ---------- Previous post was at 10:27 AM ----------
No nothing is rough. Everything rides super smooth especially for being on mud terrains. And I have an avalanche not silverado so not sure if the issues with those trucks would be present on my vehicle. When I have time ill def take it to les Schwab and let them inspect it! Thanks for the tips man.
2011Tahoe
Wa Coast
Yeah the silvers,avys and tahoes all take the same hub assembly's. les Schwab also has a scan tool that they can run the codes to see what is causing the lights to be on. Not sure if they would charge you or not though.
felixgun
felixgun
Lafayette, LA
Ah I see. I'll be off work in a week to prepare moving back to Louisiana so i'll definitely have to stop by there and see what's up... my lit up DIC is KILLING me!
edgaranah1
Corona California
This^^. Happened to me when installing my leveling kit.
Sent from my iPhone 4g using Tapatalk
InTruckDesign
SW CT,
If it lasts more than 4 hours seek medical attention.:Handshake:
Like said above, I'd check the wiring first, sounds like something got unplugged.
felixgun
felixgun
Lafayette, LA
Well it didn't get unplugged... The abs sensor/wire was split in half and hanging by a thread! $182 for the part itself before labor. It ended up costing $302 after labor at the stealership :(
edgaranah1
Corona California
The $40 sensor ended up costing 300+? Daaaammm Felix u could of done the work yourself.
felixgun
felixgun
Lafayette, LA
The sensor was $182 not $40... and yea I realize it would've been something I could've done myself but I'm in the middle of packing as i'm about to move so I really didn't have the time. There goes $300 down the drain that could've went to a BB Tune or towards a retrofit :(
Zed 71
Pacific NW
Doh!
Modded
That Guy
You ought to make the tire shop foot the bill for that. They caused it.
You also could have spliced or soldered the wire back together and threw in some heat shrink.
felixgun
felixgun
Lafayette, LA
Yea I should've done that but the manager wouldn't own up to it that his shop caused it. We actually talked about how it could be spliced/soldered/heat shrieked back together but I honestly didn't want to ghetto-rig it. I'd rather have a brand new one as it was literally hanging by a thread anyways. Looking back at it I should've definitely tried to get the discount tire manager to foot the bill but I left without trying so I guess now its a little too late :(
edgaranah1
Corona California
Felix I've seen those Sensors for 40 bucks. But knowing the STEALERSHIP they always Jack up their prices.
Modded
That Guy
Yeah shit happens. Go back and vandalize their central shop air compressor to get even! :D
---------- Post added at 08:48 PM ---------- Previous post was at 08:46 PM ----------
The Audi stealership told my bro it would be a good idea (not that is was needed or anything) to align the tires on a 12 Q7 for $300!!!:jester:
Sometimes, I think dealerships hope that their customers are clueless.
felixgun
felixgun
Lafayette, LA
The part was 182+tax at the stealership. Gmpartsdirect.com has it for 117 shipped. The issue was I wanted it fixed before we moved this upcoming Friday so I didn't want to wait all that time just to get it cheaper. I realize I just lost out on like $70 but I look at it as a pure convenience charge. The dealership is like a mile from my house and the guy I always deal with is awesome so I didn't mind giving them my business.
---------- Post added at 10:21 PM ---------- Previous post was at 10:05 PM ----------
Haha great idea. Honestly if I was the manager and that happened at the store I was managing, I would've owned up to it.
MACHO
Seattle, WA
That's ****** Felix. Glad it's all fixed but jeez at such a cost.
I'd go back to Discount Tire and explain the cost incurred from replacing damage they caused. Maybe threaten filing with BBB and/or contacting their corp office?
felixgun
felixgun
Lafayette, LA
If I wasn't moving out of Colorado tomorrow and didn't have a screaming 14 month old to deal with I definitely would do exactly that macho! Unfortunately tomorrow is the last day ill be in this state so I'm not even gonna bother. Sucks to eat up a 300 cost though :(
Drewphil
