Which is a good fuel pump for a 97 yukon?
westman995
As far as i know my fuel pump is bad. The truck will no longer run, i checked pressure and if i recall it had about 50psi. Which i hear is not enough to make the truck run. The truck will run if i pour gas in the intake so it must need a new pump.
Its a 97 yukon 4wd, 4 door. I alraedy dropped the tank and removed the pump. I grabbed the fuel line to look at it and broke it right off the pump so now i CANT replace just the motor/pump in the assembly and ill need to buy the whole assembly.
I am just wonder which pump do i want to look for to buy? I looked on autozone and they have a whole assembly for around 200, its an "airtex" i believe. And i found taht pump for under 100 at other places online so if thats not a POS ill prolly buy one of those. I just dont want it to burn up right away. Any input?? Thanks
wma4553
I bought one on Ebay for about $60 and it has been working like a champ for over 18 months. My old fuel pump was still working but I bought the new one because my gas gauge had quit and the new pump fixed the gauge problem.
W
westman995
What kind of pump is the factory one?? I heard theyre not that good, or that they dont last very long. I heard that alot of the pumps dont last very long in these trucks also.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It is a Delphi and mine lasted 244k miles. it has been left sitting for several years at one point and has been run dry several times by accident. As I said before they have been improved over time just like the injection spider. Delphi or acdelco which is renamed oem parts is the best oem some you can get.
992dr
Eastern N.C.
Go with a Delphi or ACDelco, like said they have been improved.
Dont skimp, buy it once and forget about it.
noJeepshere
Bountyfull, Utahrd
My factory pump lasted 130k miles, and was always buzzing. It would still "work" but had developed a flat spot on the motor, and every so often I would have to hit the tank with a 2x4 to bounce the motor to get it going. I replaced it with the ACDelco unit, and it has been great. It came with the upgraded plug, which I soldered and put heat-shrink tubing around it. My only real complaint is that when it gets hot (running all day, hot day) it buzzes quite loudly. Otherwise it can't be heard. That pump now has 60k on it.
W
westman995
Is there a way i can double check to be CERTAIN that that pump linked to above is going to work for me? Ill be ready to order it soon so i just want to make sure i get the right one.
---------- Post added at 01:53 PM ---------- Previous post was at 01:51 PM ----------
Also i have no idea how many pumps have been in this thing or if any, im guessing its been replaced tho. It still has the square plug on it. The truck has 211k on it and i havent had it very long.
Ive always had problems with this truck since ive gotten it, and all of a sudden the fuel pump went out, so i am HOPING that the whole time the truck didnt run good was cuz of the fuel pump..
Can a weak pump make it run bad sometimes, or would the truck jus not run at all if its weak?
SunlitComet
OBS Jedi-Do Good
based on info in your first post it is the one.
there is a link on there.: http://www.amazon.com/gp/product/compatibility-chart/B000CGM1J0/ref=au_pf_dp_chart?ie=UTF8&Make=Chevrolet%7C47&Model=Tahoe%7C499&Year=1996%7C1996&carId=001
i just had one installed on my 4dr.
---------- Post added at 04:02 PM ---------- Previous post was at 03:52 PM ----------
btw because of improvement it will look slightly different. it will include the new connector for you. solder and heat shrink if you can always better. not shown in pic is the strainer but it is installed.
look on page 3 for pics. http://s1222.photobucket.com/albums/dd482/Sunlitcomet/
W
westman995
Well i ordered that pump. Is there anything else i need to do other than install the pump? Ive never replaced one before. I keep seeing the word strainer but i dont even know what that is.. haha
Gzes
the drifting 2dr
Wichita tx
My pump lasted 180k but i dont know what it has now but its kickin good
SunlitComet
OBS Jedi-Do Good
strainer sock. already attached. like a debris filter
---------- Post added at 08:39 PM ---------- Previous post was at 08:38 PM ----------
just follow the directions really and you should be fine.
BattelWagun
Chi-Town USA
Yep, this thing, it's good insurance. And I know it's too late now, but it's good to have an empty tank because that thing is HEAVY.
W
westman995
Well lucky for me, when the pump went out there was not very much gas in it at all. So it wasnt TOO heavy atleast. I couldnt imagine this huge tank even half full and trying to move it around or drop it down.
KPOD
Michigan
Turns out I need my fuel pump replaced. Can anyone confirm the AC delco part number for a 98 2 door fuel pump? I'm looking at this one, but I'm not sure if it only fits a 4 door. http://www.amazon.com/ACDelco-MU177...ie=UTF8&qid=1352821301&sr=8-1&keywords=MU1777
I see this one works for 2 doors, but it's a Delphi unit and I'm just curious if ACDelco even makes one for 2 doors? Part FG0088: http://www.amazon.com/Delphi-FG0088-Fuel-Pump-Module/dp/B000CGM1FY
Edit: Answered my own questions, after calling around ACDelco does make one, part MU1746: http://www.amazon.com/ACDelco-MU1746-Fuel-Tank-Module/dp/B001S2TQ04
Escalade2007
