55 Watt HID Upgrade
Ed Blown Vert
San Diego, Ca.
I have been running 35 watt 6000k for a while. Bight, but wanted a bit brighter and more white.
Was just going to buy some 5000k bulbs. But they were half the price of a new kit. So I decided to upgrade to the 55 watt 5000k kit.
Since all the bulb are rated at 60w. I just replaced the ballasts. According to DDM, the 6000k should look like 5000k.
Well I drove around last night, the are a bit brighter and slightly less blue. But I don't see the 40% increase like the say.
i may just try the 5000k bulbs tonight.
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
IIRC DDM told me that their 55w bulbs were about a 1/4" longer than the 35w bulbs. You just may see a difference goin with the 5k bulbs that came with the kit if that is the case.
Pat
scottrick
i was told by ddm that the only difference is the ballast. i actually bought the 55W ones and decided that i didnt want it that bright and so they swapped the ballast for me.
Ed Blown Vert
Ed Blown Vert
San Diego, Ca.
Yep, that is what I was told. Helpful guys, there were even willing to hook a few bulbs so I could pick the color I wanted.
Ed Blown Vert
Ed Blown Vert
San Diego, Ca.
35 watt 6000k
55 watt 5000k
jomulk56
Resident Lurker
IN
That doesn't look like a really big difference.
Ed Blown Vert
Ed Blown Vert
San Diego, Ca.
Its not. The 55 is a bit brighter.
The 5000k bulbs has some yellow in it, especially on high-beams.
I will probably put the 6000k back in.
07Denali
I see a huge difference. You have to get a shot down a dark road, and the difference will jump out at you.
DenaliAK
Colder than you
Alaska
There's a significant difference, plus I'm guessing you have them in reflectors, not projectors? With HID's, the more power you have in a reflector housing isn't going to be as noticeable as with a projector, because it isn't focused light. It's just sort of throwing all that extra light everywhere.
Ed Blown Vert
Ed Blown Vert
San Diego, Ca.
True, I will look into projectors. I had someone drive towards me, it was bright. Not glaring.
But when they hit the highbeams. Holy crap, it about blinded me. And it was in the day. I gotta be careful when I flash.
Ed Blown Vert
Ed Blown Vert
San Diego, Ca.
I opened up the aperture on the camera some, because it was showing the HID's darker than what they were.
This one is a bit brighter than it should be, but you get the idea.
Denali132
Banned
I have the Bi-Xeon 35w 8000's and are bright. They make 55w Bi-Xeons? When I bought mine I think all they had in Bi-Xeon were the 35w?
qlc1964
qlc1964
i'm glad you fellas are asking ? about these h.i.d's. I want to get
a pair of them to at DDM. now with the 55 w do you get flashed
by on coming cars their thinking you have your high beams on?
But i am leaning toward the 35 watt 5000 k bulbs i want them
bright white and i just have the clear headlight housing.
Ed Blown Vert
Ed Blown Vert
San Diego, Ca.
Never got flashed with the 35 watt and so far none with the 55 watt. But I have them adjusted pretty good.
D Rollins
