You guys know how I ride... (Z71 Bumpstops inside)
Alex33
Been driving the truck with these lovely looking front fender measurements:
Here was my front bumpstop situation:
I added these:
Sadly, it's too high, measures 31.5" up front now and 32" in the rear.
Gonna shave down the bumpstops to get it back down to 31" so I can get a bit of the rake back.
I will concede that it rides a bit better now, lol. I still would like to get it lower all around.
Also want to add that the install took no time at all. I had both bumpstops installed in less than 5 minutes so that was great. I changed the oil while I was down there too.
Yuko04
"SquareBODluvr"
MN
Keeping working on it bro....You'll hit that mark!
M Hankel
Vancouver, WA
Alex, are you using BT spindles + keys to get that low? I had a set of lowering keys and now I'm kinda regretting selling them lol...
Mike
A
Alex33
Trav - I'll grab a pic before I mess with it this afternoon.
Mike - I wish I had BT spindles, I'm running the McG spindles + lowering keys. Lost a bit of turning radius. I doubt I'll swap the spindles unless I have a very good reason but my next truck will def have the BT ones.
Max
Mile High
Denver
Hey dude what is the part #? I lost it and need to order some more.
Tahoewhat
Ballin' on a Budget
TX
#15161762
From your post in 2010, had it saved.
Alex- sorry didnt text you back, didnt want to bother late.
Per Boss's post-- They lift it slightly because the stops are reinforced with a larger lip like an upside down muffin, so control arm rests against them with no room to compress
or heres the thread. lol.. http://www.tahoeyukonforum.com/forum/showthread.php?t=12391
A
Alex33
Didn't get to trim the stops tonight. Took everything out to get it going and realized I couldn't cut them with what I have. I'll have to work on it another day.
Here's a pic Trav:
Thanks Mike. I was able to shoot Max a PM as it looks like that PN has been updated with 15153959
Max
Mile High
Denver
I'm gonna try drilling and shaving mine a bit with the bench grinder at work tomorrow if they get delivered. Some guy on the silvy ss forum has belltech spindles + keys just like me and said the stock stops drilled out a bit made it ride smoother. I'll try to take pics and report findings.
Travieso
Boooooooost !
Los Skandeles, CA
Looks good Alex, i happen to be resting on my Z71 bump-stops and it's been like that for the past 3 years and no problems.. im at 32 1/2 in front and 33 in the rear. i have no gap between my rims and body.
A
Alex33
Thanks for the positive feedback guys. I'll keep it like this for a week or so but now the truck has some pretty noticeable positive camber so I need to decide to re-align it as is or tinker a little more before I take it to the alignment rack.
Max
Mile High
Denver
I drilled out some stock bumpstops today at work and installed them tonight, seems to ride smoother with less jarring over potholes. I'll drill out some Z71 stops tomorrow, found a bag with 4 pairs right after local gm dealer's driver dropped off another set I ordered :crazy:
Knobz
Santa Cruz, CA
When you say you drilled them, you drilled holes through them? Details/pics?
Max
Mile High
Denver
I'll take some pics tomorrow when I dial up the Z71s, just drilled about 8 holes through the top two depressions in the stop.
A
Alex33
I want to see these pics too, I'm actually trimming my stops tomorrow so knowing where to drill and how large a hole would be great.
Max
Mile High
Denver
Drilled out the Z71 stops, we'll see how she rides with these:
Modified vs. Stock:
A
Alex33
That looks great!! I'm on my way. Thanks!
Bentley95
