The check gears light has been coming on since the pump went out. Went to autozone and they said the knock could be clogged valves or a bad sensor because the gauge us still reading low when full. I'm honestly not sure what the knock could be, I'm new to working on cars but I'm no dummy. . . The pump I'm talking about is the oil pump. I just bought one from autozone yesterday
dude if you meant check gauges light and that happened after an oil pump change you better shut that thing down NOW! that light don't come on easily it is like a you are about to get F***** warning. And now I will say that knocking is a bearing that just got screwed.
---------- Post added at 09:30 PM ---------- Previous post was at 09:28 PM ----------
have the pressure verified with a mechanical pressure gauge in place of the vehicle one. NOW!
---------- Post added at 09:30 PM ---------- Previous post was at 09:30 PM ----------
if you have to go to a shop tow it.
Oil pump went out, changed it. Yes it was primed.. I haven't checked the bearings so I don't know. Had it towed last night will know what the problem is in a few hours
