USB cigarette lighter port
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
The other day I noticed that the second cigarette lighter port in a Sierra was actually the USB port. Has anyone tried converting one of the front two lighter slots to the USB port instead?
NathanJax
Vacation Nathan
Jax, Fl
bump...
RGNEWELL2
San Antonio, TX
I don't know your goal, but that USB port hooks to the radio and if you hook an iPhone to it, you can play the music on your iPhone through the radio and control the selections with the steering wheel radio controls.
yates ™
Resident Apple hater
Iowa
Bought the stuff to make one but did not realize there was something from the factory. P/N anyone?
yates ™
Iowa
:Handshake:
---------- Post added at 08:52 AM ---------- Previous post was at 08:34 AM ----------
Can anyone get me a pic of the back of it or tell me if it is just a regular USB plug (I would assume female plug)
messy
Banned
GM P/N 20888040 USB Port Cover
GM P/N 20944422 USB Port
GM P/N 20944418 USB Port Custom F/CMPT FLR CNSL (D07)
P/N 20944418
P/N 20944422
yates ™
Iowa
Thank you sir. I was going to try to make that plug part but now I will just order one and see what I can do with it.
---------- Post added at 09:25 AM ---------- Previous post was at 09:24 AM ----------
It looks like you can use just the cover part and put in one of these http://www.amazon.com/SANOXY-USB-Fe...&sr=8-2&keywords=female+to+female+usb+adapter. I have that piece from when I was going to try this earlier so I may try it and see if it works.
NathanJax
Vacation Nathan
Jax, Fl
20944422 USB Port
So $5 for the cover and $30 for the USB port...
but like yates said, I'd like to see the back of the port and see how it hooks up. Might be stopping by the dealer tomorrow...
You would have to have some type of plastic something to hold it in place. Probably a lot cleaner to get the pieces form the dealer.
yates ™
Iowa
Nathan use the piece I linked to at amazon, skip the factory electronics, use factory plug.
NathanJax
Vacation Nathan
Jax, Fl
where would that piece go? in place of the factory USB input? How would it be held in there?
yates ™
Iowa
In the rectangular part where the factory end would go
NathanJax
Vacation Nathan
Jax, Fl
The rectangular piece (20944418) goes in the center console.
The round piece (20944422) goes in the dash
If the $30 factory adapter has the female USB inside the dash (like the pic you posted) I'd rather it look factory...
yates ™
Iowa
I don't see how the rectangular part goes in the dash. It says it goes in the center console.
This is the rectangular piece I meant.
jdpber
GOLD MEMBER
The America
you remove one of your 500 cig lighters GM gives you and this new housing pops in.. most likely has compression clips on the back side. then use the linked connector that yates shared.. that pope into the round plastic area int he rectangle slot. then you have a couple foot USB extension (radio shack or MONOPRICE.com) adn that goes to your head unit..
i wonder how this will look in an NBS ?? humm
yates ™
Iowa
If I do it I will probably take out the one in the Center console but maybe just one of them in the dash
NathanJax
Vacation Nathan
Jax, Fl
So your saying just make a piece instead of buying the $30 piece
and your saying buy the factory piece, but pop out the factory electronics and just insert the amazon piece yates posted to the factory black plate
koomie98
