Dual Alternators - Can?
JenneK
Island of Maui
I have a spare alternator.
I want to add another battery. And need more juice for my needs.
Is there a mount that anyone knows of that would allow me to run dual alternators?
Would it just be cheaper/easier to get a higher amperage replacement instead?
Rockytfox
It's probably going to be cheaper and easier to get a bigger battery and alternator. What the heck could you possibly be running?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
on gas it may have to be custom made brackets from companies but most of them have moved on to doing 2000+ years now. there are some 200A unit round for about under $400 i think.
you can put a second battery under hood by replacing storage box with left tray. $70 in dealer parts.
---------- Post added at 07:01 PM ---------- Previous post was at 06:53 PM ----------
some have done some crazy stuff tho.
Donnie Yukonie
Yates Caretaker
hes probally running alot of electronics like a big audio system or custom lighting or both
Gzes
the drifting 2dr
Wichita tx
Yea most likely. Easiest is to get the bigger stuff but I would do both just invade 1 blew you wouldn't be stranded that fast
JenneK
JenneK
Island of Maui
My truck is my bug-out vehicle.
In the near future I want to be able to ensure I have enough power to power the following.
12K winch
Various off road lights
Frig/Freezer combo
1200W inverter (minimum)
Camp lights
Water pump for shower/toilet/kitchen
Original plans called for a solar charger for the deep cycle battery(s). But the panel(s) won't be permanently mounted on the truck. The dual or larger alternator is needed to keep the two batteries charged.
Both alternators (on mine and the parts truck) are brand new. Together they should put out 210A. (right?)
I'll pull the alternator before my parts Yukon goes to the scrap yard next Tuesday. It just got me thinking about how to actually use it instead of just storing it.
SunlitComet
OBS Jedi-Do Good
12K winch
Frig/Freezer combo
Camp lights
at an elevated idle maybe 210 between them nbs alt that drop in place are 145 amps each. $179 at amazon.
JenneK
JenneK
Island of Maui
Are my stockers 105A? Heck...does it list on the alternator? I haven't even checked...
_Dylan_
STAY FROSTY
Yes, but not at 600 rpm.
I would try to rig an idle control to get the full 105 amps at around 2000rpm.
gpracer1
Phoenix
My 140 puts out about 105 at idle but I have a very small pulley so my fans will work at idle.
After seeing those brackets I ordered a plasma cutter on amazon. :)
juggernaut26201
if you want a bigger alternator go to www.mechman.com 370 amp alternator $749 does 200 amps at 500 rpm. i have one but i need someone to answer the question of where i can buy a prefab dual alternator bracket. because i have a 1998 tahoe and am going to need 2 370 amp alternator's and 5 more batteries for a custom sound system
qukon 95
i bought a slab of steel $50.00 then made a pattern on it found a
auto welding shop to get it cut he did a good job even on the curves
in the pattern.$25.00. i did the spacers so the alt lines up with the other one. i can't the pics from my computer
but i got them in my www.photobucket.com/qlcp.
JamesinAbilene
