Wheels
PB1
So driving long distance this weekend I notice a violent vibration in my steering. Someone told me with the rims I should buy some wheel centric rings, can anyone offer advice on these?
Sent from my ADR6400L using Tapatalk 2
P
PB1
Sure they are balanced correctly?
That is what I'm doing today to ensure they are balanced right. I had to replace the idle/tire rods twice since adding the wheels!
yates ™
Resident Apple hater
Iowa
It sounds like you have some serious issues going on. Stock suspension? What wheels, offset, size, etc.?
P
PB1
01 Hoe, with stock suspensions and 20in wheels. Don't know what brand I have had them since 08.
yates ™
Iowa
So you have had to replace tie rods twice since 08? That isn't as bad as I thought you were saying. Does the vibration come on only at certain speeds?
Lets just start over here. Reexplain everything with more detail as it has completely changed with your last post.
fire730
Louisiana
Did the problem just start recently? I'm sure hope you haven't been dealing with this since 2008.
P
PB1
Yes, the rims of course did change the ride, but the shaking I had this weekend was terrible! I got the tires rotated and alignment done today.
The shaking has not come back but I had to purchase a new tire. They also say the others are bad but they still recommend those wheel spacer rings!
P
PB1
Trying to figure out the name of these wheels???
yates ™
Iowa
You still haven't answered a single question so no one on here can give you any advice.
P
PB1
I actually answered every question, so for anyone confused please read below...
I own a 2001 Tahoe, in 2008 I placed set of rims on the truck from a company called Rimco. The wheels were 20in with tires. Everything else stayed stock on the vehicle. Since purchase I have always noticed a slight vibration in the steering but was told from other owners of rims that was normal.
Fast forward a few years and I had to replace idle arms on the steering bar twice, I assumed it was normal wear and tear so this did not cause any alarm.
Fast forward to this year and the shaking in the steering has gotten progressively worse and cause one tire to wear unevenly. I replaced that tire in Jan still not overly concerned until this past weekend. Now today Firestone mentioned that adding spacers could help with the shaking. My original question was "does anyone have experience with said item"?
The reason I submitted the picture is because I do not remember the name of the rims and need that information for the spacers!
yates ™
Iowa
I think you have other issues on there that need addressed that are causing those parts to wear out that fast. If you have felt the vibration since the beginning you could try the hub centric spacers but I have not ever had the need for them so I would point more towards the wheels are bent or possibly not right in another way.
P
PB1
Thanks, what size wheels do you run? Have u had any issues with steering?
yates ™
Iowa
I have ran 17's, 20's, 22's and a few sets of 24's never a problem
CEN2MENTAL95
Banned
Expensive Long Island, NY
couple of things to consider when hunting down a vibration problem:
1) are the wheels road force balanced (not just regular static balancing)
2) are the wheels universal necesittating hub centric rings? if so get them on
3) are all 4 wheels torqued down properly?
4) whats the condition/mileage of the stock suspension?
5) any play in the tie rods/ball joints?
6) any axle grease spitting out?
M Hankel
Vancouver, WA
I had a bad vibration/shimmy in the steering wheel after installing some used 22's. The shimmy would come and go as I drove. Traced it to a tire that was worn funny from the previous rig. The guy re-balanced it a different way and it took most of the shimmy out. Now I can barely feel it at 65-70mph. After talking to the guy at the tire place, he said there are a lot of tricks to get a large wheel/tire combo to balance correctly. Sounded like he knew what he was doing and whatever he did worked, for the most part.
Mike
Conedaddy
