2" rear drop pics
Jmat
Southern Cali
Hey all, I'm almost ready to pull the trigger on a BT 2" rear drop kit for my 07 Tahoe LT. Already got a very competitive price quote from Tony. I've seen plenty of pics showing the results of 2/3 drop kits and the like, but haven't found any after pics for a 2" rear drop. If anyone could share some of their pics I'd really appreciate it. BTW, a 2/3 drop looks fantastic but it's just not the look I'm personally going for, I simply want to level my hoe. That rear end is killing me!
It's not a Hoe but you get the idea...
Before:
After:
Looking to go 2/4 in the near future, though.
KMeloney
Here's a pic of mine with just the rear done. I'm MUCH happier with it now, now that the rear AND front are done....
Jmat
Jmat
Southern Cali
Thanks a lot guys, both your trucks look sweet! Think I'll go ahead with the 2" rear drop and see how I like it... there's always room to go down lower in the future. If anyone else has pics or something else to share you're welcome to chime in.
dpmhemi
Post some pics when you get it done. I'm wanting to level rear also. Just worried that 2" may be a little too much. 1 1/2" is kinda what I was thinking of. Don't know if that's doable though.
Jmat
Jmat
Southern Cali
Will definitely update with pix, hopefully 2" does the trick. Judging by the pictures above, it should make it look a lot better. Haven't seen a 1 1/2" kit anywhere. Could go with the 2" and add a 1/2" spacer but... Is there such a thing as a 1/2" spacer?
dpmhemi
Yea, don't know if there's 1/2" spacers. Is a 2" drop kit a 3"-4" drop kit with two 1" spacers?
No a 2" drop kit uses different springs from the 2/4 kit. It's very easy to do.
Jmat
Jmat
Southern Cali
Leveling kit is IN!
OK guys, got the springs via FedEx yesterday afternoon and had them installed this morning. Talk about a noticeable difference. I have to say that her new stance totally works for me. Glad I did it. Here are a few pix.
madodger88
Seattle
Looks perfect. What did you end up with exactly and what did it cost, parts and labor? I need to get this done.
Oh, and do you know what the height difference was between front and rear before you installed?
NathanJax
Vacation Nathan
Jax, Fl
much better!
Jmat
Jmat
Southern Cali
Thanks guys, so far I'm really happy with it. The rear suspension does feel a bit stiffer but I really don't think anyone else will notice... it's a minor difference from stock.
Mike, to answer your question I went with the Belltech 2" drop rear springs and shock extender brackets. Cost was $250 for the kit which I purchased from Tony. As far as labor, I received four price quotes from several shops close to home, they ranged from $145 to $210. I ended up paying $200 to a well established shop that I know will back up their work. Prior to installing the new rear springs I measured the driver side height only. Front was 35 5/8" Rear was 38". Post installation the height is measuring: Front 35 5/8" Rear 36 1/8"... Definitely post some pix should you decide to level your ride.
madodger88
Seattle
Thanks for all the info J.T. Sounds like your ride was perfect candidate for the 2" rear drop. Mine is less than 2" diff on one side and just over on the other. Decisions decisions...
RoHoe09
Houston
thanks for the update...I bought the same kit also. Just trying to find time to do the install.
dpmhemi
Mine's the same way. Driver side rear is lower than passenger side. The fronts are 35 3/4" and rears are 37 5/8" and 38". Wonder if there's a way to level it out?
Looks good Jmat. I do like the stance.....
Jmat
Jmat
Southern Cali
:cool:
wth, ill throw in my pic of 2 in the rear as well.
Sumo, I'm definitely digging your SS wheels. I'm guessing they're 22's. When I have a few bucks to throw at my truck again, I'm gonna have to get those.. hope you don't mind.
JeffK
