Denali/Escalade Leather Shifter Installed
NathanJax
Vacation Nathan
Jax, Fl
Been wanting to do it since I saw it. I found out that the 07-08 shifter had the stitching facing you, but the 09-11 had the stitching facing away. Took all of 10 minutes. The part number for mine was 25807855.
Here's the difference in the the 2
And the shifter installed
Now, the + and - is for the manual shifting on the different transmissions. the 5.3's wont come with this so it wont work. What I did was cut the 2 black wires and I can use them for something else. Others have use it for there air suspension.
Here's a little write-up I kinda went by.
Install was pretty straight forward, remove the tilt handle by gently prying it out, then remove the top half of the column cover by pushing in on both side at once and then it will pop off. The lower portion then pulls off, it helps to have the wheel tilted all the way up for this to angle it out. Gm actually has an interesting design for the column cover, you can put two screws in it if you break the plastic tabs that hold it in so you should check to see if they are there first. Next comes the wire for the shifting and tow mode, this runs underneath the passenger side to the drivers side of the column, I used a small screw driver to release the clip then pull out the two plastic mounting barbs and it comes out no problem. You have to pay attention to how the wire is routed around another wire to hold it up though for the install. A single T-30 torx bolt holds in the shifter, on mine it was on there quite tight, I had to use a ratchet to loosen it. Once that is out the shifter pulls straight out and you swap the boot to the new shifter and start to reverse the process. The cable is a little hard to plug in as it is very tight space, the bottom cover was also a bit hard to get in just right and you have to be careful not to force it and break the tabs or you will be looking for screws to put in it. For the top start at the right rear corner where the boot is and it will be a lot easier.
Modded
That Guy
Looks good Nathan.
I was going to do this mods last summer but flaked it because I figured it was not worth the $80 a Denali/Esky shifter was gonna run.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
Looks good Nathan.
After seeing/having both. it is..
Especially when...
:laughing1:
felixgun
Lafayette, LA
looks great Nathan. I think the esky/denali shifter is a huge step up from the tahoe/yukon one that's for sure.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
definitely! Just another piece to the puzzle. Basically getting a Denali without the 6.2 and bad gas mileage. I was looking at a Denali and an Esky, but I didn't want factory Nav and the bad gas mileage.
That looks great!! I can't wait to start on my interior :)
steven13608
Nice. I do want a newer tahoe with the 6 speed shiftable tranny.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
I prefer the Esky shifter, it is leather and has stitching down the center, a little nicer design.
Denali shifter is the exact same as the Escalade shifter.
Mine is leather and has the stitching down the BACK center. As I said in the first post
To me, facing away looks MUCH cleaner.
flrmat
Eau Claire
Looks nice. I like the idea of using the up/down buttons for something else, maybe for an amp
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Nice. Maybe I'll do the same and try to find a way to make the + and - do something. Maybe they can be turned into buttons for a trailer brake controller, or a winch remote if anybody were to install that on a NNBS.
Btw, the 5.3s do come with the shifter with the beyond on 09+. I believe it's an option. I had a rental 10 Tahoe 2 years ago and it did have that.
Modded
That Guy
When I was going to do it, I was going to make the +/- buttons control the volume for my Pioneer HU, or be a toggle for my reverse light HIDs.
Then I realized I would turn them on accidentally too much.
chrisfox75
Lancaster Pa
Oh i thought they were different, my bad, i got mine installed this weekend, didnt realize that the connector was different, so i cut the connector off the old shifter and wired it to the new shifter, wow what the difference in look on my suburban, love the new look.
Chris
sellech
DAng that looks sweet.
Does the leather come in different colors?
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
Chris
Mine was the same connecter, just 2 extra wires for the + and - . I just cut those off the plug and left them there for future use.
There's a shifter for the "cashmere" interior like I have, and then there's a shifter for the "black" or whatever color the Denali/Escalade comes in.
2011Tahoe
Wa Coast
Yeah my '11 Tahoe LTZ is loaded i think with every option available and it has that same shifter. The +/- are nice for towing or winter driving.
That looks sweet man, nice work.
brice715
