Bad autoride shocks/compressor?
cstiles
Chattanooga, TN
Hi guys,
Well I am yet another victim of failing autoride.....Thankfully it looks like a job I can do on my own! I am just having a hard time figuring out if I have leaky rear shocks or if my compressor is no good. I have a 2000 Yukon XL btw.
When my rig isn't under load (just me driving) autoride kicks in for a bit and than quits. I thought that might be normal. Once I load it down though (heavy film equipment, towing a generator) The compressor is on for at least 5 minutes, it shuts off, and than starts up again in another few minutes. Definitely seems leaky! I've even heard hissing coming from the rear wheelwells.
As I'm typing this I'm leaning towards leaky air shocks, but before I place an order over at Arnott's website I wanted to check with you guys and see if there's any tips out there on how to confirm what aspect of my autoride system has gone bad.
Thanks in advance for any advice you can spare me!
OHSIXX
Milwaukee
Just got done replacing my rear shocks and compressor. Found a package deal on ebay from Arnott for $550. I did the reman'd OEM shocks so it was plug and play. I did this job on my own with a pair of jackstands and floor jack. The shocks were fairly easy-upper shock mount bolts were a ***** to remove/re-install just because your going in kinda blind on the interior side of the bolt.
The compressor is easy and hard in the same sense. Easy as splicing the factory harness over to the new compressor and re-building the dryer(comes with a dryer rebuild kit-great instructions). The hard part-all 3 mounting screws will break and snap off. Mine were torx head and after 1/4 turn they snapped. Once they snap-the compressor can be disconnected and dropped down. I used a dremel with a cutoff disc to cut the broken screws flush to the bracket. Then drilled pilot holes and used new stainless self tapping screws to hold the new compressor in place. The job is very 'do-able'.
My compressor was kickin in at startup for about 15 seconds and then kickin back on pretty frquently throughout the course of a drive(like every couple blocks)-I had nobody in the vehicle but me. And my compressor was loud as shit too. Now the truck rides great and you can barely here the compressor kick in. It turns at startup now for about 5 secs and don't here kick back in at all. The truck rides better too.
If you take on the task and run into trouble-shoot me a PM.
-J
Rivieraracing
Sounds like leaky shocks for sure, and if you don't do something about it, plan on the compressor giving out because of overuse!! Best way to find out how bad the shocks are leaking air is take a squirt bottle and mix water and liquid soap and spray it on the shock bladders, you will probably see alot of bubbling!!
I also replaced my rear shocks with Arnott's rebuilds and also bough their compressor, very nice quality replacements!! Lifetime warranty on the shocks and a very nice and quiet compressor!! Highly recommended if you wanna keep your suspension stock!
Max
Mile High
Denver
Step 1: pop hood and remove RTD fuse
Step 2: order 3/5 drop kit with new shocks from Tony
Step 3: enjoy
BLKCaddy
Houston, Texas
I still have my auto ride and shocks if your interested?
---------- Post added at 12:34 PM ---------- Previous post was at 12:32 PM ----------
I'll do it for 250 for everything
bagged_s_dime
Step 3: enjoy
Question What is the RTD fuse and what does removeing it do? And this drop kit delete the auto ride crap all together?
Alex33
Removing the RTD fuse kills power to the autoride system. The drop kit will delete everything except the compressor. The compressor you can remove on your own.
bagged_s_dime
Whats this drop kit consist of to lower it cause i got drop coils in the rear and ordering drop spindles just wondering if i need anything besides shocks to delete the air ride?
warrlac
Minneapolis, MN
How do you get rid of the SERVICE RIDE CONTROL light on the dash after you change out the shocks?
Alex33
Dunno if you got this answered, but just disconnect the battery for 60 secs or more and it will eliminate that message.
biggb20042001
H-town
if you wanna keep things factory i would suggest the monroe 40034 shocks. these are just like the exact shocks already there and they connect to the factory plugs. if you end up needing a compressor i would get recommend the arnott one.
Rivieraracing
Looks like Monroe only offers up a 1 year warranty where as Arnott offers a limited lifetime warranty on their shocks, I own Arnotts Reman Rear shocks and absolutely love them!!
biggb20042001
H-town
not wanting to get into an arguement about who has a better warranty but i prefer brand new equipment myself. i dont want no who knows how many miles used shocks on my suv. and i sure dont have the time or money to be sending shocks back and forth if ya know what i mean. monroe = brand new
Rivieraracing
No argument here, but Arnott does sell brand new AND reman rear shocks!!
biggb20042001
H-town
like i said before " If he wanted to keep things factory" i suggested the monroe 40034 shocks. when i say "factory" i mean they are direct replacement factory parts that do not change the factory setup.
rossida
