Best Leveling Kit for 2012 Z71
tarheel735
I have a 2012 Z71 and want to install a leveling kit. What is the best size? I am not going to put bigger tires, I just like the evened out look a lot better.
Also, who makes the best kit?
Thanks for the help.
felixgun
Lafayette, LA
Google "ccm off road". They make a 2.5/1 leveling kit for 07+ vehicles that a lot of people on this forum have used. I actually just bought one myself but haven't had time to go install it yet.
T
tarheel735
Thanks for the reply.
So is that 2.5 in the front and then 1 in the rear?
What is the purpose of the rear spacer?
T
tarheel735
So I guess the next question is: can you just do a 1.5" spacer for the front?
Also, does it look goofy if you keep the stock rims/tires?
Thanks again.
Blackz
I have a 2inch daystar on the front and left the rear alone, i still have the stock rims but put 285/65 nittos on, when i had the stock tires it looked good too. You can go with a 1.5 in the front and leave the rear alone.
07Z71hoe
Here is ccm with stock tires
sry for such terrible pics, I only had it like this for a day then I did 285 nitto trail grapplers
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Yes, but not that specific kit. I have their 2.25/1.5 kit. I found their kit to be very easy to install in the driveway. The directions were very clear and included instructions. I couldn't be happier with what I ended up with. Very good product experience so far. Installation did not require hassling with the front strut upper mounting bolts.
Sent from my myTouch_4G_Slide using Tapatalk
InTruckDesign
SW CT,
For stock sized tires I would recommend going with a 1.5" front lift. This will take the majority of the rake out of the truck yet won't have you sagging with the back loaded up.
Attached is a pic of one we did a few weeks ago, '12 Tahoe Z71 with 1.5" front lift and 18x9" XD Addict wheels with stock tires, rides freaking great and no rubbing at any time.
AB-Z71
Charlotte
Install leveling kit
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&vxp=mtr&item=271086413411
I bought this for my 2012 Z71 tahoe. Installed it myself in a parking lot and did not have to unbolt anything except the shock/strut on the bottom. Slid the blocks underneath and bolted it back. The key to this is using a bar that is atleast 3' long to pry the coilover up 2" when you slide the blocks under. Really simple and cheap way to lift your truck. I got 2.5" out of this and it rides the same and all my CV joints are still aligned perfect.
Keep in mind the old Z71 tahoes had torsion bars and replacing the keys on them really messed with the angles of the CV axle and the ride quality. But this keeps everything perfect.
I attached a picture of my truck so you can see what you have to do.
STORMIN08
what is the diameter of the factory hole ?????? 6mm ???? ?
or better yet , what is the replacement size ???? 3/8" ???
Denton
Waco, Texas
your link is dead, what kit did you get?
X-ray Nerd
