Tahoe has aftermarket DVD player and interior lights don't work.
DanSag
I'm assuming these vehicles interior lights run in some kind of circuit. My Tahoe has an aftermarket DVD player, it was installed by the original owner. I don't mind having it, although I'll probably never use it. To the point There are lights in the DVD player, but they only work when you flip the switch, and it doesn't work with the interior lights. My issue is that the lights in the back of the truck don't work when the door is open (I have a nice stereo and it sucks having to push the buttons on and off every time) Also on weekends i end up having people in the back seat and they can never see anything when they're getting in. I'm wondering if the original centre ceiling light is important to the functioning of the entire roof lighting system? I know none of my bulbs are burnt out, and the map lights work as well as the door lights when the doors open.
I'm just wondering if I need to hack the crap out of my DVD player so I can get some light going on in my vehicle without flipping switches and pushing buttons all the time.
Thanks Guys,
Dan
NathanJax
Vacation Nathan
Jax, Fl
There's usually a wire for the doors to power the lights. They probably didn't hook it up.
If the dvd player is over the OEM light location, you'll just have to take the dvd player down and find the OEM wiring and tap into the right wire.
If you're not good with electronics, any stereo shop could do it for less than an hours labor
D
DanSag
Yeah. That's kinda what i've been thinking. Where do you think I would find the wire you describe? would it be behind the dash.. Or in the roof?
I think I'll pull the DVD player down when the weather gets nicer.
I'm looking at doing a complete LED swap of the interior bulbs, but I don't wanna do it until I get this issue solved :(
NathanJax
Vacation Nathan
Jax, Fl
In the roof. 3 wires to the factory lights. ground, always on (so you can push the light in to turn on) and then a switched wire for the doors.
D
DanSag
Thanks, I will have to try that and report back to you.
Different off question you may know... What light bulbs are in the doors?
TejasPitt
