Box question before i start building
Midgetclown
Wallingford, CT
Hey guys havent been on in a while. Im currently in the "buying" phase of my new audio build but im trying to figure out what kind of box i want to build for my sub. I bought an Fi ssd12 a while ago and as of right now its in a terribly built 1.2cube sealed box. It sounds pretty clean and loud when i listen to metal and it hits pretty hard when i feel like playing stuff just for bass. My question is if i were to build a ported box i know it will increase spl but will it cut down on sq alot? Theres nothing i hate more than listening to music and having the bands bass drum sound like a bass drop all muffled and distorted. If anyone can clear this up for me id greatly appreciate it.
NoPh33rRaCiNg
Kent, WA
You could do ported tune around 38-40hz.
abladeafficionado
Is yours the regular or high QTS model? If it's the high QTS model, putting it in a ported box is a bad idea. The only box suitable for the high QTS model is sealed.
abladeafficionado
This is the difference between 32Hz and 40Hz on my sub. I couldn't find the specs for the regular QTS SSD 12 so I modelled up my sub. The 40Hz tune is much more peaky, and lacks the low end extension. Tuning to 32Hz gets an additional 6db at 30Hz, and maintains more low end extension. For a burp box, 40Hz is okay, but for the SQ he's wanting, 40Hz will disappoint.
Modelled up in a 2.5 ft^3 box. (the specs in the photo are in liters)
Midgetclown
Midgetclown
Wallingford, CT
As far as i know i dont have a the high qts speaker.... In past research i was told if i was to port the box then make it a 2.5' cube box tuned to 33Hz. Do you think that setup would cut down on SQ?
abladeafficionado
That's exactly what I was going to recommend. Porting to around 32Hz/33Hz is about the sweet spot for SQ while retaining good output. Tuning to anything 36Hz or above generally is for SPL because it adds quite a hump to the response curve, something you don't want.
I generally will model up a sub ported, and play around with tuning frequency until I can get the F3 to about 30Hz. Some subs that's a 31Hz tune, some it's a 34Hz tune, all depends on the sub.
Midgetclown
Midgetclown
Wallingford, CT
Thanks alot for the input.... now i can actually make some decisions on how i want to do the new audio rebuild
briannorris
