HID Reverse Lights Done The Right Way
baldd86
I did this finally on my truck and have two toggle switches hooked up to it. One switch to alternate between the hid bulb and halogen bulb so when I'm reversing. The other switch is for the tailgater switch, which will light on the hid bulb.
puckhead
CO
Any body have any advice for making a mounting bracket to make these lights fit the socket in the tail lamp housing? As is I would have to sicone the shit out of them to make them work, and even then they probably wouldnt be straight.
Also, can I hook up both sides of the HIDs to one relay? I am planning on having both HIDs and halogens come on at the same time. not worried about melting because they wont be on that long.
john
i was thinking to upgrade my back up light to HID kit, but i don't want to cut the the original tail light(damage it), also consider about the power consumption of the 35W hid kit, it will consume a lot of power, as i heard HID light will drain the battery fast,if there is 20Watt or even lower power consumption HID kit with same bulb type of the back up light will be perfect. I tried to search the HID back-up light ( reverse light) and found one site called online store of Kingtech Auto Parts Co., Ltd, It has one type HID Reverse light KT-HRL-15, it seems it can meet my requirements. Here is the link http://eshop.ktautopart.com/car-hid-...kt-hrl-15.html does anyone ever buy it before or any suggestions about this item. Hard for me to make decision, but it seems this kit looks great.
DenaliAK
Colder than you
Alaska
Couple of things:
1) A 35w HID kit shouldn't use enough power to worry about.
2) I honestly don't see the point in a 15w HID bulb. That is not going to be bright enough to matter, especially at $80/kit like the one you are looking at. It's just a gimmick market.
3) HID's will not kill your battery, especially if your truck is on, which it will presumably be when you're in reverse. Again, don't worry about it.
Big_mike
i don't get this lol...i couldn't put the light control in if i wanted to i have 4x4 and thats were all my buttons are :( have to find a different spot lol. first i need to interpret this stuff..
I have this same problem.. Is there anyway to move these buttons somewhere else or where could I mount the reverse light switch, and a couple of other switches? Any suggestions?
DenaliAK
Colder than you
Alaska
I've had the parts for this project for almost a year and still haven't done it. I'm having a hard time figuring out how to wire things, I rarely have an entire day with the truck to work on it, and the weather often keeps me from doing anything to the truck because I'm a wimp and don't like to freeze....lol.
baldd86
I have a diagram for how I wired mine I'll share in a bit
Sent from my SPH-D700 using Tapatalk
houstone003
looks good thinkin about doing it since houston is full of road rage drivers
baldd86
I kno what you mean I hate them especially on 45
baldd86
Heres how I did mine (diagram)
---------- Post added at 07:50 PM ---------- Previous post was at 07:49 PM ----------
You could probably use the area by the air bag switch
DenaliAK
Colder than you
Alaska
Nice diagram. That's pretty easy to follow.
Thanks!!
Got any output shots? I don't want a shot looking at the lights, that really doesn't tell me anything. I want to see how lit up stuff behind the truck is with HID's on.
baldd86
I did this to my sierra but it would give you a nice idea of how they will be on your suv.
SHWELL
Florida
My wife officially hates you guys...lol... This in combination with my Backup camera will make hitching the trailer so much easier and fun... Ordering everything now..
oakrdrs187
oakrdrs187
Coachella,CA
Well it's good to see my old HID thread is alive an kicking. As yous can probably tell I'm not on very often, if anyone here has questions feel free to PM me, that way I will get notified by e-mail and respond to the question. Nice job to the guy with the Sierra!!
Scott you still haven't got it done!? LMAO!
diesel1114
queens nyc
im curious where you mounted the relays ? also i have sent you a pm. can you please get back to me
also on teh diagram you have power comming from the batter im guessing off one of the auxilary post int eh engime fuse panel ?
any helpis greatly appreacite
livingez_123
Sandy, OR
I sure hope your local LEO doesn't see you use the lights while going down the road. It would be one heck of a ticket. Most states say only clear lights while backing up. If you have them on while going down the road and cause an accident......I would not want to be you.
gettygatz4life
Bronx ny
That a really good idea I would like to do that but I would need to make another hole for that mod because I connect two of the lights together for my break light and the other one for signal so I don't have reverse lights but I think I'm going to use this information and cut a little hole so I can do this mod tell me what you think
Sent from my SM-N900V using Tapatalk
justinakay79
