I want to go lower
NORCAL SS
SUV SUSPENSION GURU
It doesnt bother me to remove the spindles if the other kit is the way to go (I need to replace my lowers anyways they are shot and I am looking for a Tahoe for my wife, so I could use the drop spindles on the vehicle)...
Thoughts? I know I am monopolizing your time and for that I apologize.
jimmy
dont worry thats what im here for.
The a arms are serviceable and have zerk fittings. its both a upper and lower set up.
NORCAL SS
SUV SUSPENSION GURU
you will have lights in the dash. If you dont want any lights heres what id do.
front you can ditch the spindles and do the 3 inch control arms
in rear the belltech kit for 250 and run no spacers and then you shorten the autoride links
then in rear run the djm hardware kit to relocate the axle/swaybar links.
This way autoride still works and you can load the back of the truck up.
so djm 3 inch a arm kit front $430
rear djm hardware kit $165
rear trailblazer springs $170
rear short poly bumpstops $30
you will also need to cut off the rear bumpstop brackets
look here
http://www.djmsuspension.com/Articles new/FreeTravel.html
Also djm never was able to test the arms on 4x4 trucks so they say 2wd only. The kits ive been installing since late 06 on 4x4s with no issues at all.
Your truck looks like it sits a little higher in front so wiht the a arms in front with stock spindles and rear the kit above you will be good to go and wont have lights showing.
J
Jimmyp19
NH
look here
i'm leaning very much towards that, but my concern would be with the 4x4 because I really need it
J
Jimmyp19
NH
check these out, tell me what you think...
no spacer in the front struts, ground force 2 drop spindles stock 20....
something to me isnt right .
seem too long???
what it looks like
from center hub to lip
NORCAL SS
SUV SUSPENSION GURU
Yup ditch the shocks do the belltech front drop struts with camber bushings. Those are keeping you way up about 2 inhes to high.
so front your at 36 inches with spindles and 305 35 24??
what is the rear at 36 inches also with 3 inch drop springs?
NORCAL SS
SUV SUSPENSION GURU
No I am at 36 with 275 55 20
the rear is just about the same
36ish with the same 275 55 20 with 3 inches dropped
wow way to high. HOnestly just reading that I would do the front belltech drop struts even set at stock level will give you about 1.5 more than what you ahve now.
The rear belltech 3-4 inch kit with shock extenders will give you 1.5 inches more in rear than what you have now with spacer and 2.5 more without the spacer.
I TOTALLY brain farted right now but you dont have autoride on the truck do you?
J
Jimmyp19
NH
yes i do
man this just seems to get worse and worse
NORCAL SS
SUV SUSPENSION GURU
yes i do
lol no biggie
1) in rear do the belltech kit i have 3-4 inch adjustable springs/shock extenders/autoride links $250 shipped. Kit takes about 1 hour to put in and will get you another 1-2 inches out of the rear.
2) front since it has autoride you can do 2 things.
a) add the belltech drop springs on it which will put you 1-2 inches lower than what you have now (they are adjustable) and do the camber bushings up top which will be $260 total shipped
or
b) get rid of spinldes use stock ones and do the djm 3 inch a arm set up this will include upper/lower a arms drop you 1 inch over what you have now and will be $435 shipped
NORCAL SS
SUV SUSPENSION GURU
yes itsthe strut for sure. if you pypassed autoride in front then you can do drop struts.
J
Jimmyp19
NH
ok I feel we are getting somewhere
how much for the front drop struts and
the rear belltech 3-4 inch adjustable springs
I already have the shock extenders and autoride links in the rear
do I need the djm hardware kit too?
thanks
jimmy
NORCAL SS
SUV SUSPENSION GURU
thanks
jimmy
the 250 kit comes with
springs
shock extenders
1 inch spacers.
If you separate them springs and 1 inch spacers comes to 265 shipped. You can sell the shock extenders here im sure someone will pick them up
you dont need the djm hardware kit but if you lower it fully I would cut the brackets off the frame
375 is
front drop struts
rear drop springs
rear spacers
rear shock extenders
NORCAL SS
SUV SUSPENSION GURU
sorry should have been a 4 not a 3
drop struts 215 shipped
rear drop kti 250 shipped
J
Jimmyp19
NH
I'm gonna have to call walmart and do a price check now...................
how can I pay you? You have been such a help so far, just let me pay you hahaha
jimmy
veteran111
